Engineering ToolBox > Heat Emission from Pipes Submerged in Oil or Fat
A table with heat emission from steam or water heating pipes submerged in oil or fat. The heat transmission is indicated for assisted (forced) and natural circulation
The viscosity of a fluid has considerable influence on the heat transfer from a submerged heating pipe. Be aware that the viscosity of a fluid is highly dependent on the temperature.
steam heating coil oil tanks
The table below can be used to indicate the heat emission from a steam pipe submerged in an oil bath .
Application Fluid Heat Emission from coil surface
 (Btu/ft2 hr oF) W/m2 oC
Steam coil with medium steam pressure and natural convection of oil Light Oils 30 170
Heavy Oils 15 - 20 85 - 115
Fats 5 - 10 30 - 60
Steam coil with medium pressure and forced convection of oil Light Oils 100 570
Heavy Oils 60 340
Fats 30 170
