Engineering ToolBox > Heat Loss Diagrams Insulated Pipes
Heat loss (W/ft) diagrams for insulated pipes - ranging 1/2 to 6 inches - insulation thickness 0.5 - 4 inches - temperature difference 50 - 350 deg F
The heat loss diagrams below is based on metal pipes with fiber glass insulation with thermal conductivity 0.25 Btu/h oF ft2/in, outdoor condition with moderate wind 20 mph. A safety factor of 10% is included.
Pipe Heat Loss - Insulation thickness 4 inches
pipe heat loss diagram insulation thickness 4 inches
Pipe Heat Loss - Insulation thickness 3 inches
pipe heat loss diagram insulation thickness 3 inches
Pipe Heat Loss - Insulation thickness 2.5 inches
pipe heat loss diagram insulation thickness 2.5 inches
Pipe Heat Loss - Insulation thickness 2 inches
pipe heat loss diagram insulation thickness 2 inches
Pipe Heat Loss - Insulation thickness 1.5 inches
pipe heat loss diagram insulation thickness 1.5 inches
Pipe Heat Loss - Insulation thickness 1 inch
pipe heat loss diagram insulation thickness 1 inch
Pipe Heat Loss - Insulation thickness 0.5 inches
pipe heat loss diagram insulation thickness 0.5 inches
