Engineering ToolBox > Heat Pumps Performance and Efficiency Ratings
Rating performance and efficiency of heat pumps
Several methods are used to rate heat pump performance and efficiency
COP - Coefficient of Performance
The Coefficient of Performance - COP - is the ratio of heat output to the amount of energy input of a heat pump.
cop heat pump efficiency
COP can be expressed as
COP = hh / hw (1)
COP = Coefficient of Performance
hh = heat produced (Btu/h)
hw = equivalent electric energy input (Btu/h) = 3.413 Pw
Pw = electrical input energy (W)
If a heat pump delivers 3 units of heat for every unit of energy input - the COP is 3.
EER - Energy Efficiency Ratio
The Energy Efficiency Ratio - EER - measures the cooling efficiency of a heat pump.
EER can be expressed as
EER = hc / Pw (2)
EER = Energy Efficiency Rating
hc = cooling heat (Btu/h)
Pw = electrical power (W)
Example - EER
An air conditioner or heat pump in cooling modus draws 1000 W to produce 10000 Btu/h cooling. The EER can be calculated as
EER = 10000 (Btu/h) / 1000 (W)
    = 10
HSPF - Heating Season Performance Factor
The Heating Season Performance Factor - HSPF - is a measure of the overall heating efficiency of a heat pump.
The HSPF can be regarded as an "average" COP for an entire heating season. It is common to compare BTUs of heat output to watts of electrical energy input. HSPF of 6.8 can be compared with an average COP of 2 and a HSPF in the range of 5-7 is acceptable.
SEER - Seasonal Energy Efficiency Ratio
Seasonal Energy Efficiency Ratio is a measure of the seasonal cooling efficiency of a heat pump or a consumer central air conditioning system.
The SEER should be at least 13 to be sold in the United States. The SEER may be above 20 for a efficient system.
