Engineering ToolBox > Heater and Coolers in Ventilation Systems
Basic equations of heat transfer and selecting criteria of heaters and coolers
Classification of heater and coolers
It is often common to classify both heaters and coolers by the medium used to provide or remove the energy:
Basic Heating Equations
Heating Air
The basic equation expressing the heating process of the air in an heater can be expressed like
H = ρ cp qv (to - ti) (1)
H = heat (W)
ρ = air density (kg/m3)
cp = air specific capacity (J/kgoC)
qv = volume flow air (m3/s)
to = temperature out of the heater (oC)
ti = air temperature into the heater (oC)
Heat Transfer through Exchanger Surface
The heat transfer through a heat exchanger surface can be expressed as:
H = A dtm U (2)
A = heat surface (m2)
dtm = logarithmic mean temperature difference (oC)
U = heat transmission coefficient (W/m2K)
The heat transmission coefficient - U - depends on the air speed and the water (fluid) speed through the heater.
Water Heater
The heating process on the water (fluid) side of the heat exchanger can be expressed as
H = ρw cpw qw (twi - two) (3)
ρw = density water (kg/m3)
cpw = water specific capacity (J/kgoC)
qw = water flow (kg/s)
twi = temperature water to the heater (oC)
two = temperature water from the heater (oC)
Steam Heater
If saturated steam is used to heat the air, the heating process can be expressed as:
H = qs he (4)
qs = steam flow (kg/s)
he = evaporating enthalpy water (J/kg)
The evaporating enthalpy of water depends on the steam pressure. At one bar absolute pressure (100oC) the evaporating enthalpy is 2258 kJ/kg (539 kcal/kg). At ten bar absolute pressure (180oC) the evaporating enthalpy is 2014 kJ/kg (481 kcal/kg).
Selecting Heaters Criteria
Important design criteria when selecting heaters:
Water Heated Heaters
Steam Heated Heaters
Electrical Heated Heaters
Cooling Air
When coolers are calculated, it is important to know if the surfaces are dry or wet.
Dry Surface Cooling
For a cooler with a dry surface the same equation used for the heating process (1) may be modified and used:
Hc = ρ cp qv (ti - to) (5)
Hc = heat removed from air (W)
to = temperature out of the cooler (oC)
ti = air temperature in to the cooler (oC)
Wet Surface Cooling
For coolers with wet surfaces, the water vapor in the air is condensed and it is necessary to use the enthalpy of air in the calculations:
Hc = ρ qv (hi - ho) (6)
ho = enthalpy in the air out from the cooler (kJ/kg)
hi = enthalpy in the air into the cooler (kJ/kg)
Water (fluid) Flow through the Cooler
The water flow cooling process can be calculated with a modified formula similar as for the heating process.
Selecting Coolers Criteria
Important design criteria when selecting coolers:
