Engineering ToolBox > Horsepower Estimation for Pumps, Fans and Turbines
Horsepower is the imperial (British) unit of power. A horsepower is the ability to do work at the rate of
Note that Power is "Work per unit time" and work is "Force through distance". In gravity systems Force is Weight - mass multiplied with gravity.
The total horsepower developed by water falling from a given height is the product of the mass flow rate in pounds per minute times the falling height in feet divided by 33,000. It can be expressed as:
Php = mmin h g / 33000 (1)
Php = power (horsepower, hp)
mmin = mass flow rate per minute (lbm/min)
h = head or height (ft)
g = acceleration of gravity (32 ft/s2)
(1) can alternatively be expressed as:
Php = msec h g / 550 (1b)
msec = mass flow rate per second (lbm/s)
(1) can also be expressed as:
Php = γ Q h / 33000 (1c)
Q = volume flow rate (ft3/min)
γ = specific weight (lbf/ft3) (weight is force)
Water horsepower for flow in gal/min can be expressed as:
Pwhp = SG Qgal h / 3960 (1d)
Q = volume flow rate (gpm)
SG = specific gravity
h = head (ft)
SG for water is 1.001 at 32oF and 0.948 at 240oF.
The brake horsepower is the amount of real horsepower going to the pump, not the horsepower used by the motor. In the metric system the unit kilowatts (kW) is used.
Due to hydraulic, mechanical and volumetric losses in a pump or turbine the actual horsepower available for work on or from the fluid is less than the total horsepower supplied.
The brake horse power - bhp - for a pump or fan can be expressed as:
Pbhp = ( γ Q h / 33000 ) / η (2)
Pbhp = brake horse power (horsepower, hp)
Q = volume flow rate (ft3/min, cfm)
The brake horse power - bhp - for a turbine can be expressed as:
Pbhp = η ( γ Q h / 33000 ) (2b)
The input horsepower to the electrical motor for a pump or fan can be expressed as:
Php_el = Pbhp / ηe (3)
or
Php_el = (m h / 33000) / (η ηe) (3b)
Php_el = input power to the electrical motor
ηe = mechanical efficiency of the electrical motor
Horsepower can be converted to other common units as:
Transforming horsepower to kiloWatt can be expressed as:
PkW = 0.746 Php (4)
PkW = power (kW)
Together with the equations above it's possible to express (4) in many common combinations as:
PkW = 0,746 (m h / 33000) / η ηe (5)
