Engineering ToolBox > Measure Humidity
How to measure relative air humidity with dry and wet bulb temperatures
The air humidity can easy be estimated by measuring
humidity measurement dry wet bulbe temperature
Dry bulb temperature - Tdb - can be measured with a simple thermometer as shown above.
Wet bulb temperature - Twb - can be measured with a standard thermometer with some wet clothing, cotton or similar, around the bulb. Note that an continuously air flow is import to evaporate water from the wet clothing and achieve the correct wet bulb temperature.
Air movement can be achieved by moving the thermometer as done with a sling thermometer or similar.
Relative humidity can be estimated from the tables below or alternatively from psyhrometric diagrams.
Temperature in Fahrenheit
Relative Humidity - RH (%)
Difference Between Dry Bulb
and Wet Bulb Temperatures
 Tdb - Twb
(oF)
Dry Bulb Temperature - Tdb (oF)
60 64 68 72 76 80 84 88
1 94 95 95 95 96 96 96 96
2 90 90 90 91 91 92 92 92
3 84 85 85 86 87 88 88 89
4 78 80 81 82 83 84 84 85
5 73 75 76 78 79 80 80 81
6 68 70 72 73 75 76 77 78
7 63 66 67 69 71 72 73 74
8 58 61 63 65 67 68 70 71
9 54 57 59 61 63 65 66 68
10 49 52 55 57 59 61 63 64
dry and wet bulb temperature - relative moisture diagram degrees fahrenheit
Temperature in Celsius
 Tdb - Twb
(oC)
Dry Bulb Temperature - Tdb (oC)
15 18 20 22 25 27 30 33
1 90 91 91 92 92 92 93 93
2 80 82 83 84 85 85 86 87
3 71 73 75 76 77 78 79 80
4 62 65 67 68 70 71 73 74
5 53 57 59 61 64 65 67 69
6 44 49 52 54 57 59 61 63
7 36 42 45 47 51 53 55 58
8 28 34 38 41 45 47 50 53
9 21 27 31 34 39 41 45 48
10 13 20 25 28 33 36 40 43
dry and wet bulb temperature - relative moisture diagram degrees celsius
