Hydrogen
Chemical, Physical and Thermal Properties of Hydrogen - H2
Chemical, physical and thermal properties of Hydrogen - H2 :
Molecular Weight 2.016
Specific Gravity 0.070
Specific Volume (ft3/lb, m3/kg) 194, 12.1
Density of liquid at atmospheric pressure (lb/ft3, kg/m3) 4.43, 71.0
Absolute Viscosity (lbm/ft s, centipoises) 6.05 10-6, 0.009
Sound velocity in gas (m/s) 1315
Specific Heat - cp - (Btu/lboF or cal/goC, J/kgK) 3.42, 14310
Specific Heat Ratio - cp/cv 1.405
Gas constant - R - (ft lb/lboR, J/kgoC) 767, 4126
Thermal Conductivity (Btu/hr ft oF, W/moC) 0.105, 0.182
Boiling Point - saturation pressure 14.7 psia and 760 mm Hg - (oF, oK) -423, 20.4
Latent Heat of Evaporation at boiling point (Btu/lb, J/kg) 192, 447000
Freezing or Melting Point  at 1 atm (oF, oC) -434.6, -259.1
Latent Heat of Fusion (Btu/lb, J/kg) 25.0, 58000
Critical Temperature (oF, oC) -399.8, -240.0
Critical Pressure (psia, MN/m2) 189, 1.30
Critical Volume (ft3/lb, m3/kg) 0.53, 0.033
Flammable yes
Heat of combustion (Btu/ft3, Btu/lb, kJ/kg) 320, 62050, 144000
  • values at 25oC (77oF, 298 K) and atmospheric pressure
Search the Engineering Toolbox
  • Material Properties - Material properties - density, heat capacity, viscosity and more - for gases, fluids and solids
ToolBox Tools
3D Engineering ToolBox - draw and model technical applications! 3D Engineering ToolBox - 3D modelling of technical applications with Google SketchUp!
2D Engineering ToolBox - create and share online diagram drawing templates! 2D Engineering ToolBox - create and share online diagram drawings with Google Docs!
Engineering ToolBox Apps - mobile online and offline engineering applications! Engineering ToolBox Apps - mobile online and offline engineering applications!
Disclaimers
The content in The Engineering ToolBox is COPYRIGHTED but can be used with NO WARRANTY or LIABILITY
Important information should always be double checked with alternative sources. All applicable national and local regulations and practices concerning this aspects must be strictly followed and adhered to. Contact Us!
Desktop Edition!
