Engineering ToolBox > Calculating Indoor Temperature and Humidity Loads
The indoor climate is influenced by
The most important sources may be summarized as
Sensible heat from persons are transferred through conduction, convection and radiation. Latent heat from persons are transferred through water vapor.
The sensible heat influence on the air temperature and latent heat influence the moisture content of air.
The heat transferred from persons depends on their activity, clothing, air temperature and the number of persons in the building.
Heat transferred to the room from the lights can be calculated as
Hl = Pinst K1 K2 (1)
Hl = heat transferred from the lights (W)
Pinst = installed effect (W)
K1 = simultaneous coefficient
K2 = correction coefficient if lights are ventilated. (= 1 for no ventilation, = 0.3-0.6 if ventilated)
The table below can be used to estimate heat load from lights. (The manufacturers datasheets should be checked for details)
| Installed effect (W) | Illumination lux | ||||
| 200 | 400 | 600 | 800 | 1000 | |
| Incandescent lamp | 38 | 75 | 110 | 145 | 180 |
| Fluorescent tubes | 15 | 25 | 36 | 48 | 60 |
Normal illumination of rooms:
| Office Activity | Illumination lux |
| Normal work | 200 |
| PC work | 500 |
| Archive | 200 |
| Drawing work, normal | 500 |
| Drawing work, detailed | 1000 |
Heat transferred from electrical equipment can be calculated as
Heq = Peq K1 K2 (2)
Heq = heat transferred from electrical equipment (W)
Peq = electrical power consumption (W)
K1 = load coefficient
K2 = running time coefficient
When machines runs heat can be transferred to the room from the motor and/or the machine.
If the motor is in the room and the machine is outside the heat transferred can be calculated as
Hm = Pm / hm - Pm (3)
Hm = heat transferred from the machine to the room (W)
Pm = electrical motor power consumption (W)
hm = motor efficiency
If the motor is belt driven and the motor and belt is in the room and the machine is outside the heat transferred can be calculated as
Hm = Pm / hm - Pm hb (3b)
hb = belt efficiency
If the motor and the machine is in the room the heat transferred can be calculated as
Hm = Pm / hm (3c)
In this situation the total power is transferred as heat to the room.
Note! If the machine is a pump or a fan, most of the power is transferred as energy to the medium and may be transported out of the room.
If the motor is outside and the machine is in the room the heat transferred can be calculated as
Hm = Pm (3d)
If the motor is belt driven and the motor and belt is outside and the machine is in the room the heat transferred can be calculated as
Hm = Pm hb (3e)
Evaporation from open vessels or similar can be calculated as
qm = A (x1 - x2 ) ae (4)
qm = evaporated water (kg/s)
A = surface area (m2)
x1 = water content in saturated air at water surface temperature (kg/kg)
x2 = water content in the air (kg/kg)
ae = evaporation constant (kg/m2s)
The evaporation constant can be estimated
ae = (25 + 19v)/3600 (5)
v = air speed close to the water surface (m/s)
The temperature in the water surface will be lower than the temperature below the surface.
It can be calculated as
t1 = t2 - (t2 - t3) / 8 (6)
t1 = temperature in water surface (oC)
t2 = temperature below the surface (oC)
t3 = wet bulb temperature in the air (oC)
The heat for evaporation can be calculated as
He = qm / (x1 - x2) (h1 - h2) (7)
h1 = enthalpy in saturated air (J/kg)
h2 = enthalpy in air (J/kg)
The flow of a polluting fluid can be calculated as
qf = 22.4 qe / M T / 273 (8)
qf = flow of the fluid (m3/s)
qe = evaporated fluid
M = molecule mass of the fluid at 0 oC and 101.3 Pa (kg/mole)
T = temperature (K)
Carbon dioxide (CO2) concentration in "clean" air is 575 mg/m3.
Huge concentrations can cause headaches and the concentration should be below 9000 mg/m3.
Carbon dioxide are produced by persons during the combustion. The concentration of carbon dioxide in the air can be measured and used as an indicator of air quality.
| Activity | Respiration per person m3/h | Carbon dioxide generation per person m3/h |
| Sleeping | 0.3 | 0.013 |
| Sitting, relaxed | 0.5 | 0.02 |
| Working, moderate | 2 - 3 | 0.08 - 0.13 |
| Working, heavy | 7 - 8 | 0.33 - 0.38 |
| Product | Smell | Limit mg/m3 |
| Ammonia | Sticking | 0.5 |
| Carbon disulphid | Aromatic, little sticking | 2.6 |
| Chlorine | Sticking | 0.06 |
| Chlorate phenol | Medical | 0.18 |
| Ether | Geranium | 0.069 |
| Prussic Acid | Bitter almond | 1 |
| Hydrogen sulphid | Rotten egg | 0.26 |
| Ozone | Little sharp | 0.096 |
