Engineering ToolBox > Insulation Materials and Temperature Ranges
Temperature limits of some common insulation materials are indicated in the table below:
| Insulation Material | Low Temperature Range | High Temperature Range | ||
| oC | oF | oC | oF | |
| Calcium Silicate | -18 | 0 | 650 | 1200 |
| Cellular Glass | -260 | -450 | 480 | 900 |
| Elastomeric foam | -55 | -70 | 120 | 250 |
| Fiberglass | -30 | -20 | 540 | 1000 |
| Mineral Wool | 0 | 32 | 1000 | 1800 |
| Phenolic foam | 150 | 300 | ||
| Polyisocyanurate or polyiso | -180 | -290 | 150 | 300 |
| Polystyrene | -50 | -60 | 75 | 165 |
| Polyurethane | -210 | -350 | 120 | 250 |
Non-asbestos Calcium Silicate insulation board and pipe insulation feature with light weight, low thermal conductivity, high temperature and chemical resistance.
Cellular glass insulation is composed of crushed glass combined with a cellulating agent.
These components are mixed, placed in a mold, and then heated to a temperature of approximately 950oF. During the heating process, the crushed glass turns to a liquid. Decomposition of the cellulating agent will cause the mixture to expand and fill the mold. The mixture creates millions of connected, uniform, closed-cells and form at the end a rigid insulating material.
Cellulose is made from shredded recycled paper, such as newsprint or cardboard. It's treated with chemicals to make it fire- and insect-resistant, and is applied as loose-fill or wet-sprayed through a machine.
Fiberglass is the most common type of insulation. It's made from molten glass spun into microfibers.
Mineral wool is made from molten glass, stone or slag that is spun into a fibre-like structure. Inorganic rock or slag are the main components (typically 98%) of stone wool. The remaining 2% organic content is generally a thermosetting resin binder (an adhesive) and a little oil.
Polyurethane is an organic polymer formed by reacting a polyol (an alcohol with more than two reactive hydroxyl groups per molecule) with a diisocyanate or a polymeric isocyanate in the presence of suitable catalysts and additives.
Polyurethanes are flexible foams used in mattresses, chemical-resistant coatings, adhesives and sealants, insulation for buildings and technical applications like heat exchangers, cooling pipes and much more.
Polystyrene is an excellent insulator. It is manufactured in two ways:
Extruded polystyrene, or XPS, is a closed-cell, thermal plastic material manufactured by a variety of extrusion processes. The main applications of extruded polystyrene insulation are in building insulation and construction in general.
Molded or expanded polystyrene is commonly called beadboard and has a lower R-value than extruded polystyrene.
Polyisocyanurate or polyiso is a thermosetting type of plastic, closed-cell foam that contains a low-conductivity gas (usually hydrochlorofluorocarbons or HCFC) in its cells.
