Engineering ToolBox > ISO - Pipe, Tube and Fittings Standards and Specifications
International Organization for Standardization - ISO - pipe, tube and fittings standards and specifications
Industrial pipe, tube and fittings standards and specifications from the ISO - International Organization for Standardization:
- ISO 7-1:1994-05
Pipe threads where pressure-tight joints are made on the threads - Part 1: Dimensions, tolerances and designation - ISO 7-2:2000
Pipe threads where pressure-tight joints are made on the threads - Part 2: Verification by means of limit gauges - ISO 49:1994
Malleable cast iron fittings threaded to ISO 7-1 - ISO 228-1:2000
Pipe threads where pressure-tight joints are not made on the threads - Part 1: Dimensions, tolerances and designation - ISO 228-2:1987
Pipe threads where pressure-tight joints are not made on the threads; Part 2 : Verification by means of limit gauges - ISO 264:1976
Unplasticized polyvinyl chloride (PVC) fittings with plain sockets for pipes under pressure; Laying lengths; Metric series - ISO 265-1:1988
Pipes and fittings of plastics materials; fittings for domestic and industrial waste pipes; basic dimensions: metric series; part 1: unplasticized poly(vinyl chloride) (PVC-U) - ISO 392:1986
Asbestos-cement pipe fittings for building and sanitary purposes - ISO 580:1990
Injection-molded unplasticized poly(vinyl chloride) (PVC-U) fittings; oven test; test method and basic specifications - ISO 727-1:2002
Fittings made from unplasticized poly(vinyl chloride) (PVC-U), chlorinated poly(vinyl chloride) (PVC-C) or acrylonitrile/butadiene/styrene (ABS) with plain sockets for pipes under pressure - Part 1: Metric series - ISO 727-2:2002
Fittings made from unplasticized poly(vinyl chloride) (PVC-U), chlorinated poly(vinyl chloride) (PVC-C) or acrylonitrile/butadiene/styrene (ABS) with plain sockets for pipes under pressure - Part 2: Inch-based series - ISO 881:1980
Asbestos-cement pipes, joints, fittings/sewage/drain - ISO 1179:1981
Pipe connections, threaded to ISO 228/1, for plain end steel and other metal tubes in industrial applications - ISO 1635-2:1987
Seamless wrought copper and copper alloy tube - ISO 1651:1974
Tube drawing mandrels - ISO 1684:1975
Wire, bar and tube drawing dies; Specifications - ISO 2016:1981
Capillary solder fittings for copper tubes; Assembly dimensions and tests - ISO 2035:1974
Unplasticized polyvinyl chloride (PVC) moulded fittings for elastic sealing ring type joints for use under pressure; Pressure-resistance test - ISO 2044:1974
Unplasticized polyvinyl chloride (PVC) injection-moulded solvent-welded socket fittings for use with pressure pipe; Hydraulic internal pressure test - ISO 2048:1990
Double-socket fittings for unplasticized poly(vinyl chloride) (PVC-U) pressure pipes with elastic sealing ring type joints; minimum depths of engagement - ISO 2284:1987
Hand taps for parallel and taper pipe threads; General dimensions and marking - ISO 2507-1:1995
Thermoplastics pipes and fittings - Vicat softening temperature - Part 1: General test method - ISO 2507-2:1995
Thermoplastics pipes and fittings - Vicat softening temperature - Part 2: Test conditions for unplasticized poly(vinyl chloride) (PVC-U) or chlorinated poly(vinyl chloride) (PVC-C) pipes and fittings and for high impact resistance poly(vinyl chloride) (PVC-HI) pipes - ISO 2507-3:1995
Thermoplastics pipes and fittings - Vicat softening temperature - Part 3: Test conditions for acrylonitrile/butadiene/styrene (ABS) and acrylonitrile/styrene/acrylic ester (ASA) pipes and fittings - ISO 2531:1998
Ductile iron pipes, fittings, accessories and their joints for water or gas applications - ISO 2804:1996
Wire, bar or tube drawing dies - As-sintered pellets of hardmetal (carbide) - Dimensions - ISO 2851:1993
Stainless steel bends and tees for the food industry - ISO 2852:1993
Stainless steel clamp pipe couplings for the food industry - ISO 3183-1:1996
Petroleum and natural gas industries - Steel pipe for pipelines - Technical delivery conditions - Part 1: Pipes of requirement class A - ISO 3183-2:1996
Petroleum and natural gas industries - Steel pipe for pipelines - Technical delivery conditions - Part 2: Pipes of requirements class B - ISO 3253:1998
Gas welding equipment - Hose connections for equipment for welding, cutting and allied processes - ISO/TR 3313:1998
Measurement of fluid flow in closed conduits - Guidelines on the effects of flow pulsations on flow-measurement instruments - ISO 3419:1981
Non-alloy and alloy steel butt-welding fittings - ISO 3458:1976
Assembled joints between fittings and polyethylene (PE) pressure pipes ; Test of leakproofness under internal pressure - ISO 3459:1976
Polyethylene (PE) pressure pipes; Joints assembled with mechanical fittings; Internal under-pressure test method and requirement - ISO 3477:1981
Polypropylene (PP) pipes and fittings - density - ISO 3501:1976
Assembled joints between fittings and polyethylene (PE) pressure pipes; Test of resistance to pull out - ISO 3503:1976
Assembled joints between fittings and polyethylene (PE) pressure pipes; Test of leakproofness under internal pressure when subjected to bending - ISO 3514:1976
Chlorinated polyvinyl chloride (CPVC) pipes and fittings; Specification and determination of density - ISO 3545-1:1989
Steel tubes and fittings; symbols for use in specifications; part 1: tubes and tubular accessories with circular cross-section - ISO 3545-2:1989
Steel tubes and fittings; symbols for use in specifications; part 2: square and rectangular hollow sections - ISO 3545-3:1989
Steel tubes and fittings; symbols for use in specifications; part 3: tubular fittings with circular cross-section - ISO 3586:1976
Glass plant, pipeline and fittings; general rules for testing, handling and use - ISO 3587:1976
Glass plant, pipeline and fittings; Pipeline and fittings of nominal bore 15 to 150 mm; Compatibility and interchangeability - ISO 3603:1977
Fittings for unplasticized polyvinyl chloride (PVC) pressure pipes with elastic sealing ring type joints; Pressure test for leakproofness - ISO 3604:1976
Fittings for unplasticized polyvinyl chloride (PVC) pressure pipes with elastic sealing ring type joints; Pressure test for leakproofness under conditions of external hydraulic pressure - ISO 3633:2002
Plastics piping systems for soil and waste discharge (low and high temperature) inside buildings - Unplasticized poly(vinyl chloride) (PVC-U) - ISO 4056:1978
Polyethylene (PE) pipes and fittings- designation - ISO 4059:1978
Polyethylene (PE) pipes; Pressure drop in mechanical pipe-jointing systems; Method of test and requirements - ISO 4132:1979
Unplasticized polyvinyl chloride (PVC) and metal adaptor fittings for pipes under pressure; Laying lengths and size of threads; Metric series - ISO 4144:2003
Pipework - Stainless steel fittings threaded in accordance with ISO 7-1 - ISO 4145:1986
Non-alloy steel fittings threaded to ISO 7/1 - ISO 4230:1987
Hand- and machine-operated circular screwing dies for taper pipe threads; R series - ISO 4231:1987
Hand- and machine-operated circular screwing dies for parallel pipe threads - G series - ISO 4397:1993
Fluid power systems and components; connectors and associated components; nominal outside diameters of tubes and nominal inside diameters of hoses - ISO 4439:1979
Unplasticized polyvinyl chloride (PVC) pipes and fittings; Determination and specification of density - ISO 4422-1:1996
Pipes and fittings made of unplasticized poly(vinyl chloride) (PVC-U) for water supply - Specifications - Part 1: General - ISO 4422-2:1996
Pipes and fittings made of unplasticized poly(vinyl chloride) (PVC-U) for water supply - Specifications - Part 2: Pipes (with or without integral sockets) - ISO 4422-3:1996
Pipes and fittings made of unplasticized poly(vinyl chloride) (PVC-U) for water supply - Specifications - Part 3: Fittings and joints - ISO 4422-5:1997
Pipes and fittings made of unplasticized poly(vinyl chloride) (PVC-U) for water supply - Specifications - Part 5: Fitness for purpose of the system - ISO 4435:2003
Plastics piping systems for non-pressure underground drainage and sewerage - Unplasticized poly(vinyl chloride) (PVC-U) - ISO 4440-1:1994
Thermoplastics pipes and fittings - Determination of melt mass-flow rate - Part 1: Test method - ISO 4440-2:1994
Thermoplastics pipes and fittings - Determination of melt mass-flow rate - Part 2: Test conditions - ISO 4451:1980
Polyethylene (PE) pipes and fittings - determinati - ISO 4483:1979
Asbestos-cement pipelines; Field pressure testing - ISO 4486:1985
Asbestos-cement ventilation ducts and fittings; Dimensions and characteristics - ISO 4488:1979
Asbestos-cement pipes and joints for thrust-boring and pipe jacking - ISO 4704:1977
Glass plant, pipeline and fittings; Glass plant components - ISO/TR 5168:1998
Measurement of fluid flow - Evaluation of uncertainties - ISO 5251:1981
Stainless steel butt-welding fittings - ISO 5256:1985
Steel pipes and fittings for buried or submerged pipe lines; External and internal coating by bitumen or coal tar derived materials - ISO 5361:1999
Anaesthetic and respiratory equipment - Tracheal tubes and connectors - ISO 5730:1992
Stationary shell boilers of welded construction (other than water-tube boilers) - ISO 5969:1979
Ground thread taps for pipe threads G series and Rp series; Tolerances on the threaded portion - ISO 6207:1992
Seamless nickel and nickel alloy tube - ISO 6447:1983
Rubber seals; Joint rings used for gas supply pipes and fittings; Specification for material - ISO 6448:1985
Rubber seals; Joint rings used for petroleum product supply pipes and fittings; Specification for material - ISO 6455:1983
Unplasticized polyvinyl chloride (PVC) fittings with elastic sealing ring type joints for pipes under pressure; Dimensions of laying lengths; Metric series - ISO 6594:1983
Cast iron drainage pipes and fittings; Spigot series - ISO 6605:2002
Hydraulic fluid power - Hoses and hose assemblies - Test methods - ISO 6761:1981
Steel tubes; Preparation of ends of tubes and fittings for welding - ISO 6964:1986
Polyolefin pipes and fittings; Determination of carbon black content by calcination and pyrolysis; Test method and basic specification - ISO/TR 7074:1986
Performance requirements for plastics pipes and fittings for use in underground drainage and sewage - ISO 7228:1993
Tracheal tube connectors - ISO 7245:1984
Pipes and fittings of acrylonitrile-butadiene- styrene (ABS); General specification for moulding and extrusion materials - ISO 7246:1984
Pipes and fittings of acrylonitrile/styrene/ acrylester (ASA); General specification for moulding and extrusion materials - ISO 7268:1983
Pipe components; Definition of nominal pressure - ISO 7278-2:1988
Liquid hydrocarbons; dynamic measurement; proving systems for volumetric meters;
part 2: pipe provers - ISO 7279:1984
Polypropylene (PP) fittings for pipes under pressure; Sockets for fusion using heated tools; Metric series; Dimensions of sockets - ISO 7370:1982
Glass fibre reinforced thermosetting plastics (GRP) pipes and fittings; Nominal diameters, specified diameters and standard lengths - ISO 7387-1:1983
Adhesives with solvents for assembly of u PVC pipe elements; Characterization; Part 1 : Basic test methods - ISO 7608:1985
Shipbuilding; Inland navigation; Couplings for disposal of oily mixture and sewage water - ISO 7671:2003
Plastics piping systems for soil and waste discharge (low and high temperature) inside buildings - Polypropylene (PP) - ISO 7675:2003
Plastic piping systems for soil and waste discharge (low and high temperature) inside buildings - Chlorinated poly(vinyl chloride) (PVC-C) - ISO 7682:2003
Plastics piping systems for soil and waste discharge (low and high temperature) inside buildings - Acrylonitrile-butadiene-styrene (ABS) - ISO 7686:1992
Plastics pipes and fittings; opacity; test method - ISO 8142:1990
Thermal insulation; bonded preformed man-made mineral fiber pipe sections; specification - ISO 8283-1:1991
Plastics pipes and fittings; dimensions of sockets and spigots for discharge systems inside buildings; part 1: unplasticized poly(vinyl chloride) (PVC-U) and chlorinated poly(vinyl chloride) (PVC-C) - ISO 8283-2:1992
Plastics pipes and fittings; dimensions of sockets and spigots for discharge systems inside buildings; part 2: polyethylene (PE) - ISO 8283-3:1992
Plastics pipes and fittings; dimensions of sockets and spigots for discharge systems inside buildings; part 3: polypropylene (PP) - ISO 8283-4:1992
Plastics pipes and fittings; dimensions of sockets and spigots for discharge systems inside buildings; part 4: acrylonitrile/butadiene/styrene (ABS) - ISO 8361-1:1991
Thermoplastics pipes and fittings; water absorption;
part 1: general test method - ISO 8361-2:1991
part 2: test conditions for unplasticized poly(vinyl chloride) (PVC-U) pipes and fittings - ISO 8361-3:1991
part 3: test conditions for acrylonitrile/butadiene/styrene (ABS) pipes and fittings - ISO 8434-1, :1994
Metallic tube connections for fluid power and general use -
Part 1: 24 compression fittings - ISO 8434-2:1994
Metallic tube fittings for fluid power and general use -
Part 2: 37 flared fittings - ISO 8434-3:1995
Part 3: O-ring face seal fittings - ISO 8434-4:1995
Part 4: 24 cone connectors with O-ring weld-on nipples - ISO 8434-5:1995
Part 5: Test methods for threaded hydraulic fluid power connections - ISO 8491:1998
Metallic materials - Tube (in full section) - Bend test - ISO 8492:1998
Metallic materials - Tube - Flattening test - ISO 8493:1998
Metallic materials - Tube - Drift-expanding test - ISO 8494:1998
Metallic materials - Tube - Flanging test - ISO 8495:1998
Metallic materials - Tube - Ring-expanding test - ISO 8496:1998
Metallic materials - Tube - Ring tensile test - ISO 8497:1994
Thermal insulation; determination of steady-state thermal transmission properties of thermal insulation for circular pipes - ISO 8572:1991
Pipes and fittings made of glass-reinforced thermosetting plastics (GRP); definitions of terms relating to pressure, including relationships between them, and terms for installation and jointing - ISO 8770:2003
Plastics piping systems for soil and waste discharge (low and high temperature) inside buildings - Polyethylene (PE) - ISO 8772:1991
High density polyethylene (PE-HD) pipes and fittings for buried drainage and sewerage systems; specifications - ISO 8773:1991
Polypropylene (PP) pipes and fittings for buried drainage and sewerage systems; specifications - ISO 8796:2004
Polyethylene PE 32 and PE 40 pipes for irrigation laterals - Susceptibility to environmental stress cracking induced by insert-type fittings - Test method and requirements - ISO 9080:2003
Plastics piping and ducting systems - Determination of the long-term hydrostatic strength of thermoplastics materials in pipe form by extrapolation - ISO 9095:1990
Steel tubes; continuous character marking and colour coding for material identification - ISO 9261:2004
Agricultural irrigation equipment - Emitters and emitting pipe - Specification and test methods - ISO 9356:1989
Polyolefin pipe assemblies with or without jointed fittings; resistance to internal pressure; test method - ISO 9623:1997
PE/metal and PP/metal adaptor fittings for pipes for fluids under pressure - Design lengths and size of threads - Metric series - ISO 9625:1993
Mechanical joint fittings for use with polyethylene pressure pipes for irrigation purposes - ISO 9691:1992
Rubber; recommendations for the workmanship of pipe joint rings; description and classification of imperfections - ISO 9803:1993
Vacuum technology; pipeline fittings; mounting dimensions - ISO/TR 9824-1:1990
Measurement of free surface flow in closed conduits;
part 1: methods - ISO 9808:1990
Solar water heaters; elastomeric materials for absorbers, connecting pipes and fittings; method of assessment - ISO/TR 9824-2:1990
part 2: equipment - ISO 9853:1991
Injection-moulded unplasticized poly(vinyl chloride) (PVC-U) fittings for pressure pipe systems; crushing test - ISO 10147:1994
Pipes and fittings made of crosslinked polyethylene (PE-X) - Estimation of the degree of crosslinking by determination of the gel content - ISO/TR 10358:1993
Plastics pipes and fittings; combined chemical-resistance classification table - ISO 10400:1993
Petroleum and natural gas industries; formulae and calculation for casing, tubing, drill pipe and line pipe properties - ISO 10420:1994
Petroleum and natural gas industries; flexible pipe systems for subsea and marine riser applications - ISO 10422:2001
Petroleum and natural gas industries - Threading, gauging and thread inspection of casing, tubing and line pipe - ISO 10508:1995
Thermoplastics pipes and fittings for hot and cold water systems - ISO 10806:2003
Pipework - Fittings for corrugated metal hoses - ISO/TR 10837:1991
Determination of the thermal stability of polyethylene (PE) for use in gas pipes and fittings - ISO 10928:1997
Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Methods for regression analysis and their use - ISO 10931-1:1997
Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Part 1: General - ISO 10931-2:1997
Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Part 2: Pipes - ISO 10931-3:1996
Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Part 3: Fittings - ISO 10931-4:1997
Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Part 4: Valves - ISO 10931-5:1998
Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Part 5: Fitness for purpose of the system - ISO/TR 11295:1992
Techniques for rehabilitation of pipeline systems by the use of plastics pipes and fittings - ISO 11413:1996
Plastics pipes and fittings - Preparation of test piece assemblies between a polyethylene (PE) pipe and an electrofusion fitting - ISO 11414:1996
Plastics pipes and fittings - Preparation of polyethylene (PE) pipe/pipe or pipe/fitting test piece assemblies by butt fusion - ISO 11420:1996
Method for the assessment of the degree of carbon dispersion polyolefin pipe, fittings and compounds - ISO 11496:1993
Seamless and welded steel tubes for pressure purposes; ultrasonic testing of tube ends for the detection of laminar imperfections - ISO/TR 11647:1996
Fusion compatibility of polyethylene (PE) pipes and fittings - ISO 11961:1996
Petroleum and natural gas industries - Steel pipes for use as drill pipe - Specification - ISO 12162:1995
Thermoplastics materials for pipes and fittings for pressure applications - Classification and designation - Overall service (design) coefficient - ISO 13664:1997
Seamless and welded steel tubes for pressure purposes - Magnetic particle inspection of the tube ends for the detection of laminar imperfections - ISO 13665:1997
Seamless and welded steel tubes for pressure purposes - Magnetic particle inspection of the tube body for the detection of surface imperfections - ISO 13761:1996
Plastics pipes and fittings - Pressure reduction factors for polyethylene pipeline systems for use at temperatures above 20 - ISO 13783:1997
Plastics piping systems - Unplasticized poly(vinyl chloride) (PVC-U) end-load-bearing double-socket joints - Test method for leaktightness and strength while subjected to bending and internal pressure
