Engineering ToolBox > ISO Valve Standards
An overview of International Organization for Standardization - ISO - valve standards
ISO - International Organization for Standardization - valve standards:
- ISO 683-15:1992
Heat-treatable steels, alloy steels and free-cutting steels; part 15: valve steels for internal combustion engines - ISO 4126-1:2004
Safety devices for protection against excessive pressure - Part 1: Safety valves - ISO 4401:1994
Hydraulic fluid power - Four-port directional control valves - Mounting surfaces - ISO 4411:1986
Hydraulic fluid power; Valves; Determination of pressure differential/flow characteristics - ISO 4422-4:1997
Pipes and fittings made of unplasticized poly(vinyl chloride) (PVC-U) for water supply - Specifications - Part 4: Valves and ancillary equipment - ISO 5208:1993
Industrial valves; pressure testing of valves - ISO 5209:1977
General purpose industrial valves; Marking - ISO 5210:1991
Industrial valves; multi-turn valve actuator attachments - ISO 5211:2001
Industrial valves - Part-turn actuator attachment - SO 5599-1:2001
Pneumatic fluid power - Five-port directional control valves - Part 1: Mounting interface surfaces without electrical connector - ISO 5599-2:2001
Pneumatic fluid power - Five-port directional control valves - Part 2: Mounting interface surfaces with optional electrical connector - ISO 5599-3:1990
Pneumatic fluid power; five-port directional control valves; part 3: code system for communication of valve functions - ISO 5752:1982
Metal valves for use in flanged pipe systems; Face-to-face and center-to-face dimensions - ISO 5781:2000
Hydraulic fluid power - Pressure-reducing valves, sequence valves, unloading valves, throttle valves and check valves - Mounting surfaces - ISO 5996:1984
Cast iron gate valves - ISO 6002:1992
Bolted bonnet steel gate valves - ISO 6182-1:2004
Fire protection - Automatic sprinkler systems - Part 1: Requirements and test methods for sprinklers - ISO 6182-2:1993
Fire protection; automatic sprinkler systems; part 2: requirements and test methods for wet alarm valves, retard chambers and water motor alarms - ISO 6182-3:1993
Fire protection; automatic sprinkler systems; part 3: requirements and test methods for dry pipe valves - ISO 6182-4:1993
Fire protection; automatic sprinkler systems; part 4: requirements and test methods for quick-opening devices - ISO 6182-5:1995
Fire protection - Automatic sprinkler systems - Part 5: Requirements and test methods for deluge valves - ISO 6263:1997
Hydraulic fluid power - Compensated flow-control valves - Mounting surfaces - ISO 6264:1998
Hydraulic fluid power - Pressure-relief valves - Mounting surfaces - ISO 6403:1988
Hydraulic fluid power; valves controlling flow and pressure; test methods - ISO 6552:1980
Automatic steam traps; Definition of technical terms - ISO 6553:1980
Automatic steam traps; Marking - ISO 6554:1980
Flanged automatic steam traps; Face-to-face dimensions - ISO 6704:1982
Automatic steam traps; Classification - ISO 6948:1981
Automatic steam traps; Production and performance characteristic tests - ISO 7121:1986
Flanged steel ball valves - ISO 7244:1984
Air distribution and air diffusion; Aerodynamic testing of dampers and valves - ISO 7259:1988
Predominantly key-operated cast iron gate valves for underground use - ISO 7368:1989
Hydraulic fluid power; two-port slip-in cartridge valves; cavities - ISO 7508:1985
Unplasticized polyvinyl chloride (PVC-U) valves for pipes under pressure; Basic dimensions; Metric series - ISO 7714:2000
Agricultural irrigation equipment - Volumetric valves - General requirements and test methods - ISO 7790:1997
Hydraulic fluid power - Four-port modular stack valves and four-port directional control valves, sizes 02, 03 and 05 - Clamping dimensions - ISO 7841:1988
Automatic steam traps; determination of steam loss; test methods - DIN ISO 7967-3:1993
Reciprocating internal combustion engines; vocabulary of components and systems; valves, camshaft drive and actuating mechanisms - ISO 8233:1988
Thermoplastics valves; torque; test method - ISO 8242:1989
Polypropylene (PP) valves for pipes under pressure; basic dimensions; metric series - ISO 8659:1989
Thermoplastics valves; fatigue strength; test method - ISO 9393-1:2004
Thermoplastics valves for industrial applications - Pressure test methods and requirements - Part 1: General - ISO 9393-2:1997
Thermoplastics valves - Pressure test methods and requirements - Part 2: Test conditions and basic requirements for PE, PP, PVC-U and PVDF valves - ISO 9635:1990
Irrigation equipment; hydraulically operated irrigation valves - ISO 9644:1993
Agricultural irrigation equipment; pressure losses in irrigation valves; test method - ISO 9911:1993
Agricultural irrigation equipment; manually operated small plastics valves - ISO 9952:1993
Agricultural irrigation equipment; check valves - ISO 10418:2003
Petroleum and natural gas industries - Offshore production installations - Basic surface process safety systems - ISO 10423:2003
Petroleum and natural gas industries - Drilling and production equipment - Wellhead and christmas tree equipment, - ISO 10497:2004
Testing of valves - Fire type-testing requirements - ISO 10522:1993
Agricultural irrigation equipment; direct-acting pressure-regulating valves - ISO 10631:1994
Metallic butterfly valves for general purposes - ISO 10931-4:1997
Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Part 4: Valves - ISO 10933:1997
Polyethylene (PE) valves for gas distribution systems
