Engineering ToolBox > Isopropanol (2-Propanol) based Water Solutions
Freezing and flash points of isopropanol (2-Propanol) based water solutions - brines
Isopropyl alcohol is also commonly used as a cleaner and solvent in industry. It is also used as a gasoline additive for dissolving water or ice in fuel lines.
Freezing Point of Isopropanol (2-Propanol) based Water Solutions
Freezing Point
Isopropanol Concentration
(% by volume)
0 10 20 30 40 50 60 70 80 90 100
Temperature (oF) 32 25 20 5 0 -5 -10 -20 -35 -70 -130
(oC) 0 -4 -7 -15 -18 -21 -23 -29 -37 -57 -73
Flash Points of Isopropanol (2-Propanol) based Water Solutions
The flash point of a chemical is the lowest temperature where it will evaporate enough fluid to form a combustible concentration of gas. The flash point is an indication of how easy a chemical may burn.
Flash Point
(% by volume)
Temperature (oF) - 105 85 75 70 65 65 65 65 65 53
(oC) - 41 29 24 21 18 18 18 18 18 12
Alternatives to Isopropanol (2-Propanol) based Water Solutions
