Engineering ToolBox > Online Kinematic Viscosity Calculator
Convert between different kinematic viscosity units - centistokes, poise, lentor and more
Kinematic Viscosity Units Online Calculator
The calculator below can be used to convert between common kinematic viscosity units:
Value (use period as decimal point)
m2/sec m2/min m2/hour stokes (cm2/sec) cm2/hour cm2/min in2/sec in2/min in2/hour ft2/sec ft2/min ft2/hour
Kinematic Viscosity Converter Table
The table below can be used to convert betweeen some common kinematic viscosity units:
Multiply with
Convert from Convert to
m2/sec 1 60 3600 10000 3.6 107 6 105
m2/min 0.017 1 60 167 6 105 104
m2/hour 2.8 10-4 0.017 1 2.78 10000 167
stokes (cm2/sec) 10-4 0.006 0.36 1 3600 60
cm2/hour 2.8 10-8 1.7 10-6 10-4 2.7 10-4 1 0.0167
cm2/min 1.7 10-6 10-4 0.006 0.0167 60 1
in2/sec 6.45 10-4 0.039 2.32 6.45 2.3 104 387
in2/min 1.1 10-5 6.45 10-4 0.039 0.11 387 6.45
in2/hour 1.79 10-7 1.1 10-5 6.45 10-4 1.79 10-3 6.45 0.11
ft2/sec 0.093 5.56 333.3 926 3.33 106 5.56 104
ft2/min 0.0015 0.093 5.57 15.5 5.6 104 928.8
ft2/hour 2.6 10-5 1.55 10-3 0.09 0.26 928 15.5
Multiply with
m2/sec 1550 9.3 104 5.58 106 10.8 646 38800
m2/min 25.8 1550 9.3 104 0.18 10.8 647
m2/hour 0.43 25.8 1550 0.003 0.179 10.8
stokes (cm2/sec) 0.155 9.3 558 0.001 0.0646 3.88
cm2/hour 4.3 10-5 0.0026 0.155 3 10-7 1.79 10-5 0.0011
cm2/min 0.0026 0.155 9.3 1.8 10-5 0.0011 0.065
in2/sec 1 60 3600 0.007 0.42 25.03
in2/min 0.017 1 60 1.2 10-4 6.9 10-3 0.42
in2/hour 2.8 10-4 0.017 1 1.9 10-6 1.16 10-4 6.95 10-3
ft2/sec 143.5 8611 5.2 105 1 59.8 3592.6
ft2/min 2.4 144 8638 0.017 1 60
ft2/hour 0.04 2.4 143.8 2.78 10-4 0.017 1
Common Kinematic Viscosity Units
