Engineering ToolBox > KVA
Apparent, True Applied and Reactive Power
Total electrical power consumption depends on real power - electrical energy consumption, and reactive power - imaginary power consumption, and can be expressed (power triangle or Pythagorean relationship) as
Wapparent = ( Wtrue applied2 + Wreactive2 )1/2 (1)
Wapparent = apparent total power (Kilovolt Amps)
Wtrue applied = true applied power (Kilowatts)
Wreactive = reactive inductive power (Kilovolt Amps reactive)
Reactive Inductive Power
Reactive Power - Wreactive - is measured in volt-amperes reactive (VAR) and is the power stored in and discharged by the inductive motors, transformers or solenoids.
Reactive power required by inductive loads increases the amount of apparent power - measured in kilovolt amps (kVA) - in the distribution system. Increasing the reactive and apparent power causes the power factor - PF - to decrease.
