Engineering ToolBox > Laminar, Transitional or Turbulent Flow?
It is important to know if the fluid flow is laminar, transitional or turbulent when calculating heat transfer or pressure and head loss.
There are in general three types of fluid flow in pipes:
Laminar flow
Laminar flow generally happens when dealing with small pipes and low flow velocities. Laminar flow can be regarded as a series of liquid cylinders in the pipe, where the innermost parts flow the fastest, and the cylinder touching the pipe isn't moving at all.
Shear stress in laminar flow is independent of the density - ρ, and the shear stress depends almost only on the viscosity - μ.
Turbulent flow
In turbulent flow vortices, eddies and wakes make the flow unpredictable. Turbulent flow happens in general at high flow rates and with larger pipes.
Shear stress for turbulent flow is a function of the density - ρ.
Transitional flow
Transitional flow is a mixture of laminar and turbulent flow, with turbulence in the center of the pipe, and laminar flow near the edges. Each of these flows behave in different manners in terms of their frictional energy loss while flowing, and have different equations that predict their behavior.
Turbulent or laminar flow is determined by the dimensionless
Reynolds Number
The Reynolds number is important in analyzing any type of flow when there is substantial velocity gradient (i.e., shear.) It indicates the relative significance of the viscous effect compared to the inertia effect. The Reynolds number is proportional to [inertial force] divided by [viscous force].
The flow is
