Engineering ToolBox > Cooling Loads - Latent and Sensible Heat
Latent and sensible cooling loads to consider in design of HVAC systems
The design cooling load (or heat gain) is the amount of heat energy to be removed from a house by the HVAC equipment to maintain the house at indoor design temperature when worst case outdoor design temperature is being experienced. There are two types of cooling loads:
The sensible cooling load refers to the dry bulb temperature of the building and the latent cooling load refers to the wet bulb temperature of the building. In the summer, humidity influence in the selection of the HVAC equipment and the latent load as well as the sensible load must be calculated.
Factors that influence to the sensible cooling load
Notice that below grade walls, below grade floors, and floors on concrete slabs do not increase the cooling load on the structure and are therefore ignored.
Other sensible heat gains are taken care of by the HVAC equipment before the air reaches the rooms (system gains). Two items that require additional sensible cooling capacity from the HVAC equipment are:
Factors that influence to the latent cooling load
Moisture is introduced into a structure through:
Other latent heat gain is taken care of by the HVAC equipment before the air reaches the rooms (system gain).
