Engineering ToolBox > 2nd Law of Thermodynamics
The second law is concerned with entropy, which is a measure of disorder. The second law says that the entropy of the universe increases
There are two classical statements of the second law of thermodynamics:
Kelvin & Planc
"No (heat) engine whose working fluid undergoes a cycle can absorb heat from a single reservoir, deliver an equivalent amount of work, and deliver no other effect"
Clausius
"No machine whose working fluid undergoes a cycle can absorb heat from one system, reject heat to another system and produce no other effect"
Both statements of the second law place constraints on the first law by identifying that energy goes downhill.
The second law is concerned with entropy (S). Entropy is produced by all processes and associated with the entropy production is the loss of ability to do work. The second law says that the entropy of the universe increases. An increase in overall disorder is therefore spontaneous. If the volume and energy of a system are constant, then every change to the system increases the entropy. If volume or energy change, then the entropy of the system actually decrease. However, the entropy of the universe does not decrease.
For energy to be available there must be a region with high energy level and a region with low energy level. Useful work must be derived from the energy that would flows from the high level to the low level.
Efficiency of a heat machine
The efficiency of a heat machine working between two energy levels is defined in terms of absolute temperature:
η = ( Th - Tc ) / Th = 1 - Tc / Th(1)
η = efficiency
Th = temperature high level (K)
Tc = temperature low level (K)
As a consequence, to attain maximum efficiency the Tc would have to be as cold as possible. For 100% efficiency the Tc would have to equal 0 K. This is practically impossible, so the efficiency is always less than 1 (less than 100%).
Change in entropy > 0, irreversible process Change in entropy = 0, reversible process Change in entropy < 0, impossible process
Entropy is used to define the unavailable energy in a system. Entropy defines the relative ability of one system to act to an other. As things moves toward a lower energy level, where one is less able to act upon the surroundings, the entropy is said to increase.
Entropy definition
Entropy is defined as :
S = H / T (2)
S = entrophy (kJ/kg K)
H = enthalpy (kJ/kg)
T = absolute temperature (K)
A change in the entropy of a system is caused by a change in its heat content, where the change of entropy is equal to the heat change divided by the average absolute temperature (Ta):
dS = dH / Ta (3)
The sum of (H / T) values for each step in the Carnot cycle equals 0. This only happens because for every positive H there is a countering negative H, overall.
Carnot Heat Cycle
In a heat engine, a gas is reversibly heated and then cooled. A model of the cycle is as follows: State 1 --(isothermal expansion) --> State 2 --(adiabatic expansion) --> State 3 --(isothermal compression) --> State 4 --(adiabatic compression) --> State 1
State 1 to State 2: Isothermal Expansion
Isothermal expansion occurs at a high temperature Th, dT = 0 and dE1 = 0. Since dE = H + w, w1 = - H1. For ideal gases, dE is dependent on temperature only.
State 2 to State 3: Adiabatic Expansion
The gas is cooled from the high temperature, Th, to the low temperature, Tc. dE2 = w2 and H2 = 0 (adiabatic).
State 3 to State 4: Isothermal Compression
This is the reverse of the process between states 1 and 2. The gas is compressed at Tc. dT = 0 and dE3 = 0. w3 = - H3
State 4 to State 1: Adiabatic Compression
This is the reverse of the process between states 2 and 3. dE4 = w4 and H4 = 0 (adiabatic).
The processes in the Carnot cycle can be graphed as the pressure vs. the volume. The area enclosed in the curve is then the work for the Carnot cycle because w = - integral (P dV). Since this is a cycle, dE overall equals 0. Therefore,
-w = H = H1 + H2 + H3 + H4
If you decrease Tc, then the quantity -w gets larger in magnitude.
if -w > 0 then H > 0 and the system, the heat engine, does work on the surroundings.
The laws of thermodynamics were determined empirically (by experiment). They are generalizations of repeated scientific experiments. The second law is a generalization of experiments dealing with entropy--it is that the dS of the system plus the dS of the surroundings is equal to or greater then 0.
Example - Entropy Heating Water
A process raises 1 kg of water from 0 to 100oC (273 to 373 K) under atmospheric conditions.
Specific enthalpy at 0oC (hf) = 0 kJ/kg (from steam tables) (Specific - per unit mass)
Specific enthalpy of water at 100oC (hf) = 419 kJ/kg (from steam tables)
Change in specific entropy:
dS = dH / Ta
    = (419 - 0) / ((273 + 373)/2)
    = 1.297 kJ/kgK
Example - Entropy Evaporation Water to Steam
A process changes 1 kg of water at 100oC (373 K) to saturated steam at 100oC (373 K) under atmospheric conditions.
Specific enthalpy of steam at 100oC (373 K) before evaporating = 0 kJ/kg (from steam tables)
Specific enthalpy of steam at 100oC (373 K) after evaporating = 2 258 kJ/kg (from steam tables)
dS = dH / Ta
    = (2 258 - 0) / ((373 + 373)/2)
    = 6.054 kJ/kgK
The total change in specific entropy from water at 0oC to saturated steam at 100oC is the sum of the change in specific entropy for the water, plus the change of specific entropy for the steam.
Example - Entropy Superheated Steam
A process superheats 1 kg of saturated steam at atmospheric pressure to 150oC (423 K).
Specific total enthalpy of steam at 100oC (373 K) = 2 675 kJ/kg (from steam tables)
Specific total enthalpy of superheated steam at 150oC (373 K) = 2 777 kJ/kg (from steam tables)
dS = dH / Ta
    = (2 777 - 2 675) / ((423 + 373)/2)
    = 0.256 kJ/kgK
