Engineering ToolBox > Mach Number
The Mach Number is a dimensionless value useful for analyzing fluid flow dynamics problems where compressibility is a significant factor.
The Mach Number can be expressed as
M = v / c (1)
M = Mach number
v = fluid flow velocity (m/s, ft/s)
c = speed of sound (m/s, ft/s)
Alternatively the Mach Number can be expressed with the density and the bulk modulus for elasticity as
M = v (ρ / E)1/2 (2)
ρ = density of fluid (kg/m3, lb/ft3)
E = bulk modulus elasticity (N/m2 (Pa), lbf/in2 (psi))
The bulk modulus elasticity has the dimension pressure and is commonly used to characterize the fluid compressibility.
The square of the Mach number is the Cauchy Number.
M2 = C (3)
C = Cauchy Number
An aircraft flies at velocity 500 mph at an altitude of 35.000 ft. The surrounding temperature is -60 oF.
The sound velocity at this altitude with this temperature can be calculated as
c = [k R T]1/2
= [1,4 1716 (ft.lb/slug.oR) (-60 + 460 (oR))]1/2
= 980 ft/s
k = 1.4
R = 1716 (ft.lb/slug.oR)
The velocity of the aircraft can be calculated as
v = 500 (mi/hr) 5280 (ft/mi) / 3600 (s/hr)
= 733 ft/s
The Mach Number can be calculated as
M = 733 (ft/s) / 980 (ft/s)
= 0.75 - the aircraft is flying at subsonic speed
