Engineering ToolBox > Machine Processing and Tolerance Grades
Relation of machine processes to tolerance grades
Machining processes that under normal conditions will produce work within the tolerances indicated.
Tolerance Grades
4 5 6 7 8 9 10 11 12 13
Lapping and Honing
Cylindrical Grinding
Surface Grinding
Diamond Turning
Diamond Boring
Broaching
Reaming
Turning
Boring
Milling
Planning and Shaping
Drilling
ANSI B4.1 Standard Tolerances are indicated in the diagram below:
