Engineering ToolBox > Equation of Mechanical Energy
The equation of mechanical energy in terms of Energy per Unit Mass, Energy per Unit Volume and Energy per Unit Weight involving head
The Energy Equation is a statement of the first law of thermodynamics. The energy equation involves energy, heat transfer and work. With certain limitations the mechanical energy equation can be compared to the Bernoulli Equation and transferred to the
The Mechanical Energy Equation in Terms of Energy per Unit Mass
The mechanical energy equation for a pump or a fan can be written in terms of energy per unit mass:
pin / ρ + vin2 / 2 + g hin + wshaft = pout / ρ + vout2 / 2 + g hout + wloss (1)
p = static pressure
ρ = density
v = flow velocity
g = acceleration of gravity
h = elevation height
wshaft = net shaft energy inn per unit mass for a pump, fan or similar
wloss = loss due to friction
The energy equation is often used for incompressible flow problems and is called the Mechanical Energy Equation or the Extended Bernoulli Equation.
The mechanical energy equation for a turbine can be written as:
pin / ρ + vin2 / 2 + g hin = pout / ρ + vout2 / 2 + g hout + wshaft + wloss (2)
wshaft = net shaft energy out per unit mass for a turbine or similar
Equation (1) and (2) dimensions are
Efficiency
According to (1) a larger amount of loss - wloss - result in more shaft work required for the same rise of output energy. The efficiency of a pump or fan process can be expressed as:
η = (wshaft - wloss) / wshaft (3)
The efficiency of a turbine process can be expressed as:
η = wshaft/ (wshaft + wloss) (4)
The Mechanical Energy Equation in Terms of Energy per Unit Volume
The mechanical energy equation for a pump or a fan (1) can also be written in terms of energy per unit volume by multiplying (1) with fluid density - ρ:
pin + ρ vin2 / 2 + γ hin + ρ wshaft = pout + ρ vout2 / 2 + γ hout + wloss (5)
γ = ρ g = specific weight
The dimensions of equation (5) are
The Mechanical Energy Equation in Terms of Energy per Unit Weight involves Heads
The mechanical energy equation for a pump or a fan (1) can also be written in terms of energy per unit weight by dividing with gravity - g:
pin / γ + vin2 / 2 g + hin + hshaft = pout / γ + vout2 / 2 g + hout + hloss (6)
hshaft = wshaft / g = net shaft energy head inn per unit mass for a pump, fan or similar
hloss = wloss / g = loss head due to friction
The dimensions of equation (6) are
Head is the energy per unit weight.
hshaft can also be expressed as:
hshaft = wshaft / g = Wshaft / m g = Wshaft / γ Q (7)
Wshaft = shaft power
m = mass flow rate
Q = volume flow rate
Example - Pumping Water
Water is pumped from an open tank at level zero to an open tank at level 10 ft. The pump adds four horsepowers to the water when pumping 2 ft3/s.
Since vin = vout = 0, pin = pout = 0 and hin = 0 - equation (6) can be modified to:
hshaft = hout + hloss
or
hloss = hshaft - hout (8)
Equation (7) gives:
hshaft = Wshaft / γ Q = (4 hp)(550 ft.lb/s/hp) / (62.4 lb/ft3)(2 ft3/s) = 17.6 ft
Combined with (8):
hloss = (17.6 ft ) - (10 ft) = 7.6 ft
The pump efficiency can be calculated from (3) modified for head:
η = ((17.6 ft) - (7.6 ft)) / (17.6 ft)= 0.58
