Methane
Chemical, Physical and Thermal Properties of Methane - CH4
Chemical, physical and thermal properties of Methane - CH4 :
Molecular Weight 16.044
Specific Gravity (gas related to air) 0.554
Specific Volume (ft3/lb, m3/kg) 24.2, 1.51
Density of liquid at atmospheric pressure (lb/ft3, kg/m3) 26.3, 421
Absolute Viscosity (lbm/ft s, centipoises) 7.39 10-6, 0.011
Sound velocity in gas (m/s) 446
Specific Heat - cp - (Btu/lboF or cal/goC, J/kgK) 0.54, 2260
Specific Heat Ratio - cp/cv 1.31
Gas constant - R - (ft lb/lboR, J/kgoC) 96, 518
Thermal Conductivity (Btu/hr ft oF, W/moC) 0.02, 0.035
Boiling Point - saturation pressure 14.7 psia and 760 mm Hg - (oF, oC) -259, -161.7
Latent Heat of Evaporation at boiling point (Btu/lb, J/kg) 219.2, 510000
Freezing or Melting Point  at 1 atm (oF, oC) -296.6, -182.6
Latent Heat of Fusion (Btu/lb, J/kg) 14, 32600
Critical Temperature (oF, oC) -116, -82.3
Critical Pressure (psia, MN/m2) 673, 4.64
Critical Volume (ft3/lb, m3/kg) 0.099, 0.0062
Flammable yes
Heat of combustion (Btu/ft3, Btu/lb, kJ/kg) 985, 2290, -
  • values at 25oC (77oF, 298 K) and atmospheric pressure
Search the Engineering Toolbox
  • Material Properties - Material properties - density, heat capacity, viscosity and more - for gases, fluids and solids
ToolBox Tools
3D Engineering ToolBox - draw and model technical applications! 3D Engineering ToolBox - 3D modelling of technical applications with Google SketchUp!
2D Engineering ToolBox - create and share online diagram drawing templates! 2D Engineering ToolBox - create and share online diagram drawings with Google Docs!
Engineering ToolBox Apps - mobile online and offline engineering applications! Engineering ToolBox Apps - mobile online and offline engineering applications!
Disclaimers
The content in The Engineering ToolBox is COPYRIGHTED but can be used with NO WARRANTY or LIABILITY
Important information should always be double checked with alternative sources. All applicable national and local regulations and practices concerning this aspects must be strictly followed and adhered to. Contact Us!
Desktop Edition!
