Engineering ToolBox > CM - Circular Mil Area
The circular mil is a unit of area used especially when denoting the cross-sectional size of a wire or cable.
Mils of circular wire or cable can be calculated as:
mils = 1000 d (1)
d = diameter of cable or wire (inches)
Mils of a 1 inch wire:
mils = 1000 1 (in)
= 1000
Mils of a 1/2 inch wire:
mils = 1000 1/2 (in)
= 500
The circular mil area of a wire or cable is equal to its diameter - expressed in mils - squared:
CM = mil 2 (2)
CM = circular mil area (CM)
The diameter in mil of a circular wire can be expressed as:
mil = CM1/2 (2b)
The mil area of an 3/8 in wire (0.375 in or 375 mil) can be calculated as
CM = 375 (mils) 375 (mils)
= 140,625 CM
The mil of an circular wire with area 140.325 CM can be calculated as
mil = 140,6251/2
= 375 mils
The square mil is the area of a square whose sides are one mil, or 1 x 10-3 inch, and can be expressed as:
One Square Mil = (1 x 10-3)2
= 1 x 10-6 in2
