Engineering ToolBox > Molecular Mass of Air
Dry air is a mixture of gases where the molecular weight can be calculated by adding the weight of each component
The molecular mass of a substance is the mass of one molecule of that substance and is expressed in terms of the molecular mass unit u (equal to 1/12 the mass of one atom of carbon-12). The molecular mass can be calculated as the sum of the atomic masses of all the atoms of any one molecule.
Components in Dry Air
The two most dominant components in dry air are Oxygen and Nitrogen. Oxygen has an 16 atomic unit mass and Nitrogen has a 14 atomic units mass. Since both these elements are diatomic in air - O2 and N2, the molecular mass of Oxygen is 32 and the molecular mass of Nitrogen is 28.
Since air is a mixture of gases the total mass can be estimated by adding the weight of all major components as shown below:
Components in Dry Air Volume Ratio compared to Dry Air Molecular Mass - M
(kg/kmol)
Molecular Mass in Air
Oxygen 0.2095 32.00 6.704
Nitrogen 0.7809 28.02 21.88
Carbon Dioxide 0.0003 44.01 0.013
Hydrogen 0.0000005 2.02 0
Argon 0.00933 39.94 0.373
Neon 0.000018 20.18 0
Helium 0.000005 4.00 0
Krypton 0.000001 83.8 0
Xenon 0.09 10-6 131.29 0
Total Molecular Mass of Air 28.97
Water Vapor
Water vapor is almost always presence in dry air. The content may vary and the maximum capacity of water vapor in dry air depends on the temperature.
Water vapor - H2O - is composed of one Oxygen atom and two Hydrogen atoms. Hydrogen is the lightest element at 1 atomic unit while Oxygen is 16 atomic units. Thus the water vapor atom has an atomic mass of 18 atomic units. At 18 atomic units, water vapor is lighter than diatomic Oxygen with 32 units and diatomic Nitrogen with 28 units.
