Engineering ToolBox > NEMA Insulation Classes
Insulation systems are rated by standard NEMA classifications according to maximum allowable operating temperatures
Insulation systems are rated by standard NEMA (National Electrical Manufacturers Association) classifications according to maximum allowable operating temperatures as follows:
Temperature Tolerance Class Maximum Operation Temperature Allowed Allowable Temperature Rise at full load
1.0 service factor motor 1)
Allowable
Temperature Rise
1.15 service factor motor 1)
oC oF oC oC
A 105 221 60 70
B 130 266 80 90
F 155 311 105 115
H 180 356 125 -
1) Allowable temperature rises are based upon a reference ambient temperature of 40oC. Operation temperature is reference temperature + allowable temperature rise + allowance for "hot spot" winding. Example Temperature Tolerance Class F: 40oC + 105oC + 10oC = 155oC.
In general a motor should not operate on temperatures above the maximums. Each 10oC rise above the ratings may reduce the motor's lifetime by one half.
Temperature Tolerance Class B is the most common insulation class used on most 60 cycle US motors. Temperature Tolerance Class F is the most common for international and 50 cycle motors.
