Engineering ToolBox > Normally Closed (NC)
The term Normally Closed (NC) applies to manual valves or dampers which the operator must leave closed in normal operation.
A control valve which should go to closed position on control signal failure should be labeled FC, i.e. Fail Closed. The control signal may be pneumatic, hydraulic or electric.
