Engineering ToolBox > NPS - "Nominal Pipe Size" and DN - "Diametre Nominal"
Pipe is a ubiquitous product in the construction industry. It is made of a wide variety of materials - galvanized steel, black steel, copper, cast iron, concrete, and various plastics such as ABS, PVC, CPVC, polyethylene, and polybutylene, among others.
Pipes are identified by "nominal" or "trade" names that are loosely related to the actual dimensions. For instance, a 2-inch galvanized steel pipe has an inside diameter of about 2 1/8 inches and an outside diameter of about 2 5/8 inches.
It is common to identify pipes by inches using NPS or "Nominal Pipe Size". The metric equivalent is called DN or "diametre nominel". The metric designations conform to International Standards Organization (ISO) usage and apply to all plumbing, natural gas, heating oil, and miscellaneous piping used in buildings. The use of NPS does not conform to American Standard pipe designations where the term NPS means "National Pipe Thread Straight".
| Diameter Nominal - DN - (mm) | Nominal Pipe Size - NPS - (inches) |
| 6 | 1/8 |
| 8 | 1/4 |
| 10 | 3/8 |
| 15 | 1/2 |
| 20 | 3/4 |
| 25 | 1 |
| 32 | 1 1/4 |
| 40 | 1 1/2 |
| 50 | 2 |
| 65 | 2 1/2 |
| 80 | 3 |
| 100 | 4 |
| 150 | 6 |
| 200 | 8 |
| 250 | 10 |
| 300 | 12 |
| 350 | 14 |
| 400 | 16 |
| 450 | 18 |
| 500 | 20 |
| 550 | 22 |
| 600 | 24 |
| 650 | 26 |
| 700 | 28 |
| 750 | 30 |
| 800 | 32 |
| 900 | 36 |
| 1000 | 40 |
| 1100 | 42 |
| 1200 | 48 |
| 1400 | 54 |
| 1500 | 60 |
| 1600 | 64 |
| 1800 | 72 |
| 2000 | 80 |
| 2200 | 88 |
