Engineering ToolBox > Online Noise Rating - NR - Calculator
An online Noise Rating - NR - Calculator
The calculator below can used to calculate the NR - Noise Rating:
Sound Pressure Level (dB) - Octave band mid-frequency (Hz)
31.5 Hz
62.5 Hz
125 Hz
250 Hz
500 Hz
1000 Hz
2000 Hz
4000 Hz
8000 Hz
The NR-diagram with the default values above are indicated below:
nr - noise rating diagram example
