Engineering ToolBox > Orifice, Nozzle and Venturi Flow Rate Meters
The orifice, nozzle and venturi flow rate meters use the Bernoulli Equation to calculate the fluid flow rate by using the pressure difference between an obstruction in the flow.
In flow metering devices based on the Bernoulli Equation the downstream pressure after an obstruction will be lower than the upstream pressure before the obstruction. To understand orifice, nozzle and venturi meters it's therefore necessary to explore the Bernoulli Equation.
The Bernoulli Equation and Flow Meters
Assuming a horizontal flow (or neglecting a minor elevation difference between the measuring points) the Bernoulli Equation can be modified to:
p1 + 1/2 ρ v12 = p2 + 1/2 ρ v22 (1)
p = pressure
ρ = density
v = flow velocity
Vertical flow can be adapted by adding elevation heights h1 and h2 in (1).
Assuming that the velocity profiles are uniform in the upstream and downstream section the Continuity Equation gives:
q = v1 A1 = v2 A2 (2)
q = flow rate
A = flow area
Combining (1) and (2), assuming A2 < A1, gives the "ideal" equation:
q = A2 [ 2(p1 - p2) / ρ(1 - (A2 / A1)2) ]1/2 (3)
For a given geometry (A), the flow rate can be determined by measuring the pressure difference p1 - p2.
The theoretical flow rate q will in practice be smaller (2 - 40%) due to the geometrical conditions.
The ideal equation (3) can be modified with a discharge coefficient:
q = cd A2 [ 2(p1 - p2) / ρ(1 - (A2 / A1)2) ]1/2 (3b)
cd = discharge coefficient
The discharge coefficient cd is a function of the jet size - or orifice opening - the
area ratio = Avc / A2
Avc = area in "vena contracta"
Vena Contracta is the minimum jet area that appears just downstream of the restriction. The viscous effect is usually expressed in terms of the nondimensional parameter Reynolds Number Re.
Due to the Benoulli and Continuity Equation the velocity of the fluid will be at it's highest, and the pressure at it's lowest in "vena contracta". After the metering device and "vena contracta" the velocity decrease to the same level as before the obstruction. The pressure recover to a pressure level lower than the pressure before the obstruction and adds a head loss to the flow.
Equation (3) can be modified with diameters to:
q = cd π/4 D22 [ 2(p1 - p2) / ρ(1 - d4) ]1/2 (4)
D2 = orifice, venturi or nozzle inside diameter
D1 = upstream and downstream pipe diameter
d = D2 / D1 diameter ratio
π = 3.14
Equation (4) can be modified to mass flow for fluids by simply multiplying with the density:
m = cd π/4 D22 ρ [ 2(p1 - p2) / ρ(1 - d4) ]1/2 (5)
When measuring the mass flow in gases, its necessary to considerate the pressure reduction and change in density of the fluid. The formula above can be used with limitations for applications with relatively small changes in pressure and density.
The Orifice Plate
The orifice meter consists of a flat orifice plate with a circular hole drilled in it. There is a pressure tap upstream from the orifice plate and another just downstream. There are in general three methods of placing the taps. The coefficient of the meter depends upon the position of taps.
orifice flow meter
The discharge coefficient - cd - varies considerably with changes in area ratio and the Reynolds number. A discharge coefficient - cd - of 0.60 may be taken as standard, but the value varies noticeably at low values of the Reynolds number.
Discharge Coefficient - cd
Diameter Ratio
d = D2 / D
1
Reynolds Number - Re
104 105 106 107
0.2 0.60 0.595 0.594 0.594
0.4 0.61 0.603 0.598 0.598
0.5 0.62 0.608 0.603 0.603
0.6 0.63 0.61 0.608 0.608
0.7 0.64 0.614 0.609 0.609
The pressure recovery is limited for an orifice plate and the permanent pressure loss depends primarily on the area ratio. For an area ratio of 0.5, the head loss is about 70 - 75% of the orifice differential.
References
The Venturi Meter
In the venturi meter the fluid is accelerated through a converging cone of angle 15-20o and the pressure difference between the upstream side of the cone and the throat is measured and provides the signal for the rate of flow.
venturi flow meter
The fluid slows down in a cone with smaller angle (5-7o) where most of the kinetic energy is converted back to pressure energy. Because of the cone and the gradual reduction in the area there is no "vena contracta". The flow area is at minimum at the throat.
High pressure and energy recovery makes the venturi meter suitable where only small pressure heads are available.
A discharge coefficient - cd - of 0.975 may be taken as standard, but the value varies noticeably at low values of the Reynolds number.
The pressure recovery is much better for the venturi meter than for the orifice plate.
References
The Nozzle
Nozzles used for determining fluid's flowrate through pipes can be in three different types:
Diameter Ratio
d = D2 / D
1
104 105 106 107
0.2 0.968 0.988 0.994 0.995
0.4 0.957 0.984 0.993 0.995
0.6 0.95 0.981 0.992 0.995
0.8 0.94 0.978 0.991 0.995
References
Example - Kerosene Flow Through a Venturi Meter
The pressure difference dp = p1 - p2 between upstream and downstream is 100 kPa (1 105 N/m2). The specific gravity of kerosene is 0.82.
Upstream diameter is 0.1 m and downstream diameter is 0.06 m.
Density of kerosene can be calculated as:
ρ = 0.82 1000 (kg/m3)= 820 (kg/m3)
Upstream and downstream area can be calculated as:
A1 = 3.14 (0,1 (m)/2)2 = 0.00785 (m2)
A2 = 3.14 (0,06 (m)/2)2 = 0.002826 (m2)
Theoretical flow can be calculated from (3):
q = A2 [ 2(p1 - p2) / ρ(1 - (A2/A1)2) ]1/2
q = 0.002826 [ 2 1x105 (N/m2) / 820 (kg/m3)(1 - ( 0.002826 (m2)/0.00785 (m2) )2) ]1/2
    = 0.047 (m3/s)
For a pressure difference of 1 kPa (0,01x105 N/m2) - the theoretical flow can be calculated:
q = 0.002826 [ 2 0.01x105 (N/m2) / 820 (kg/m3)(1 - ( 0.002826 (m2)/0.00785 (m2) )2) ]1/2
    = 0.0047 (m3/s)
The mass flow can be calculated as:
m = q ρ
    = 0.0047 (m3/s) 820 (kg/m3)
    = 3.85 (kg/s)
Flow Rate and Change in Pressure Difference
Note! - The flow rate varies with the square root of the pressure difference.
From the example above:
Transmitters and Control System
The nonlinear relationship have impact on the pressure transmitters operating range and requires that the electronic pressure transmitters have the capability to linearizing the signal before transmitting it to the control system.
Accuracy
Due to the non linearity the turn down rate is limited. The accuracy strongly increases in the lower part of the operating range.
