Engineering ToolBox > Propagation of Sound Outdoors
Outdoor propagation of sound - distance and attenuation.
Single Sound Source - Spherical Propagation
The sound energy in the propagation direction of the sound is inversely proportional to the increasing surface area the sound  propagates through. The sound pressure level in a spherical distance - r - from a single sound source can be expressed as:
Lp = Lw - 10 log( 4 Π r2)       (1)
Lp = sound pressure level (dB)
Lw = sound power level source in decibel (dB)
r = distance from source   (m)
(1) can also be expressed as:
Lp = Lw - 20 log( r) + K'      (1b)
K' = -11 (single sound source  and spherical distance)
Single Sound Source - Hemi Spherical Propagation
When the sound source propagates hemi spherically with the source near ground, the constant can be set to
Note! When the distance - r - from a power source doubles, the sound pressure level decreases with 6 dB. This relationship is also known as the inverse square law.
Other factors affecting the radiation of the sound are the direction of the source, barriers between the source and the receiver, and atmospheric conditions. Equation (1) can be modified to:
Lp = Lw - 20 log r + K' + DI - Aa - Ab      (2)
DI = directivity index
Aa = attenuation due to atmospheric conditions
Ab = attenuation due to barriers
Linear Sound Source
With a linear sound source, like a road or high way with heavy traffic, the sound pressure can be expressed as:
Lp = Lw - 10 log( 4 Π r)       (3)
Note! When the distance - r - from a linear power source doubles, the sound pressure level decreases with 3 dB.
