Engineering ToolBox > Pressure Drop Diagram PE, PEH and PVC Pipes
The pressure drop in PE, PEH and PVC plastic pipes with water can be estimated from the diagram below:
The pressure drop in a PEH pipe with inside diameter 250 mm and water flow 50 l/s can be estimated to be approximately 3.5 bar/100m as indicated in the diagram below. The flow velocity is approximately 1 m/s.
