Engineering ToolBox > Pipe Formulas
Pipe and Tube Equations - moment of inertia, section modulus, traverse metal area, external pipe surface and traverse internal area - imperial units
Online Pipe Formula Calculator
outside diameter (in)
inside diameter (in) - (default values: STD 4 inches - Carbon, Alloy and Stainless Steel Pipes - ASME/ANSI B36.10/19
The calculator is based on the piping formulas and equations below:
Moment of Inertia
Moment of inertia can be expressed as
I  = 0.0491 (do4 - di4)
I = moment of inertia (in4)
do = outside diameter (in)
di = inside diameter (in)
Section Modulus
Section modulus can be expressed as
Z  = 0.0982 (do4 - di4) / do
Z = section modulus (in3)
Transverse Metal Area
Transverse metal area can be expressed as
Am  = π (do2 - di2) / 4
Am = transverse metal area (in2)
External Pipe Surface
External pipe or tube surface per ft of length can be expressed as
Ao  = π do / 12
Ao = external  pipe surface area (ft2 per ft pipe)
Internal Pipe Surface
Internal pipe or tube surface per ft of length can be expressed as
Ai  = π di / 12
Ai = internal  pipe surface area (ft2 per ft pipe)
Transverse Internal Area
Transverse internal area can be expressed as
Aa  = 0.7854 di2
Aa = transverse internal area (in2)
Circumference External
External circumference can be expressed as
Ce  = π do
Ce =  external circumference (in)
Circumference Internal
Internal circumference can be expressed as
Ci  = π di
Ci =  internal circumference (in)
