Engineering ToolBox > Schedule Terminology
An introduction to pipes and the schedule terminology
For all pipe sizes the outside diameter (O.D.) remains relatively constant. The variations in wall thickness affects only the inside diameter (I.D.).
Welded and Seamless Wrought Steel Pipe
To distinguish different weights of pipe, it is common to use the Schedule terminology from ANSI/ASME B36.10 Welded and Seamless Wrought Steel Pipe:
Note that many of the schedules are identical in certain sizes.
Stainless Steel Pipe
For stainless steel pipes thru 12-inch, schedule numbers from Schedule 5S to schedule 80S are used as published in ANSI/ASME 36.19M Stainless Steel Pipe.
