Engineering ToolBox > Pipe Equations
Calculate cross-sectional area, weight of empty pipes, weight of pipes filled with water, inside and outside surface area
Pipe cross-sectional area, empty pipe weight, pipe filled with water weight, inside and outside pipe surface area for a unit length pipe can be calculated with the equations below.
pipe diameter cross sectional area
Cross Sectional Area
Cross-sectional Area of a Steel Pipe can be calculated as
A = 0.785 di 2
A = cross-sectional area of pipe (Square Inches)
di = inside diameter (inches)
Weight of Empty Steel Pipes
Weight of empty steel pipes can be calculated as
wp = 10.6802 t (do - t)
wp =weight of steel pipe (Pounds per Foot Pipe)
t = pipe wall thickness (Inches)
do = outside diameter (inches)
Weight of Water in Pipes filled with Water
Weight of water in pipes filled with water can be calculated as
ww = 0.3405 di 2
ww = weight of steel pipe filled with water (Pounds per Foot Pipe)
Outside Surface Area of Pipes
Outside surface area of steel pipes can be calculated as
Ao = 0.2618 do
Ao = outside area of pipe - per foot (Square Feet)
Inside Surface Area of Pipes
Inside surface area of steel pipes can be calculated as
Ai = 0.2618 di
Ai = inside area of pipe - per foot (Square Feet)
Area of the Metal
Area of the metal can be calculated as
Am = 0.785 (do 2 - di 2)
Am = area of the metal (Square inches)
