Engineering ToolBox > Power Plant Performance Factors
Power plants and heat rate, thermal efficiency, capacity factor, load factor, economic efficiency, operational efficiency, energy efficiency
The performance of a power plant can be expressed through some common performance factors as
Heat Rate (Energy Efficiency)
Overall thermal performance or energy efficiency for a power plant for a period can be defined as
φhr = H / E (1)
φhr = heat rate (Btu/kW, kJ/kW)
H = heat supplied to the power plant for a period (Btu, kJ)
E = energy output from the power plant in the period (kWh)
Thermal Efficiency
Thermal efficiency of a power plant can be expressed as
μte = 100 3412.75 / φ (2)
μte = thermal efficiency (%)
Capacity Factor
The capacity factor for a power plant is the ratio between average load and rated load for a period of time and can be expressed as
μcf = 100 Pal / Prl (3)
μcf = capacity factor (%)
Pal = average load for the power plant for a period (kW)
Prl = rated capacity for the power plant (kW)
Load Factor
Load factor for a power plant is the ratio between average load and peak load and can be expressed as
μlf = 100 Pal / Ppl (4)
μlf = load factor (%)
Ppl = peak load for the power plant in the period (kW)
Economic Efficiency
Economic efficiency is the ratio between production costs, including fuel, labor, materials and services, and energy output from the power plant for a period of time. Economic efficiency can be expressed as
φee = C / E (5)
φee = economic efficiency (cents/kW, euro/kW, ...)
C = production costs for a period (cents, euro, ..)
Operational Efficiency
Operational efficiency is the ratio of the total electricity produced by the plant during a period of time compared to the total potential electricity that could have been produced if the plant operated at 100 percent in the period.
Operational efficiency can be expressed as
μoe = 100 E / E100% (6)
μeo = operational efficiency (%)
E100% = potential energy output from the power plant operated at 100% in the period (kWh)
