Engineering ToolBox > Compressed Air Pipelines - Online Pressure Drop Calculator
The pressure drop in compressed air lines can be calculated by using the formula
dp = 7.57 q1.85 L 104 / d5 p (1)
dp = pressure drop (kg/cm2)
q = air volume flow (m3/min)
L = length of pipe (m)
d = inside diameter of pipe (mm)
p = initial pressure (kg/cm2)
The calculator below can used to calculate the pressure drop in compressed air pipelines.
Calculations can be done for other pressures and/or pipe lengths by using this excel spreadsheet.
Pressure drops in 100 m (330 ft) compressed air schedule 40 steel pipe lines are indicated in the tables below:
