Engineering ToolBox > Pressure Loss in Schedule 40 Steel Pipes
Water flow and pressure loss in schedule 40 steel pipes - Imperial and SI units - gallons per minute, liters per second and cubic meters per hour
The tables below indicates friction loss for water flow through ASME/ANSI B36.10/19 schedule 40 steel pipe.
The pressure drop calculations are made with the D'Arcy-Weisbach Equation.
Nominal Pipe Size: 3/8"
Flow Velocity Pressure Drop
(m3/s) (liter/s) (US gpm) (m/s) (ft/s) (Pa/100m) (mmH2O/100m) (psi/100ft) (ftH2O/100ft)
3.0E-50.030.480.240.81145511680.511.17
4.0E-50.040.630.331.071909119470.841.95
5.0E-50.050.790.411.342850429071.262.9
6.0E-50.060.950.491.63913739911.734.0
7.0E-50.071.110.571.875197152992.35.3
8.0E-50.081.270.652.16618367492.96.8
9.0E-50.091.430.732.48161583223.68.3
1.0E-40.11.590.812.798108100044.310.0
1.1E-40.111.740.92.9118710121055.212.1
1.2E-40.121.90.983.2137457140166.114.0
1.3E-40.132.11.063.5161321164507.116.5
1.4E-40.142.21.143.7181897185488.018.6
Nominal Pipe Size: 1/2"
3.0E-50.030.480.1530.536983770.1630.38
4.0E-50.040.630.20.6761806300.270.63
5.0E-50.050.790.260.8490409220.40.92
6.0E-50.060.950.311.01242612670.551.27
7.0E-50.071.110.361.171651016840.731.69
8.0E-50.081.270.411.342103821450.932.1
9.0E-50.091.430.461.512596126471.152.6
1.0E-40.11.590.511.673122831841.383.2
1.1E-40.111.740.561.843679237521.633.8
1.2E-40.121.90.612.04378544651.944.5
1.3E-40.132.10.662.24999850982.25.1
1.4E-40.142.20.712.35798659132.65.9
1.5E-40.152.40.772.56471765992.96.6
1.6E-40.162.50.822.77363375083.37.5
1.7E-40.172.70.872.88312584763.78.5
1.8E-40.182.90.923.09052992314.09.2
1.9E-40.193.00.973.2100868102854.510.3
2.0E-40.23.21.023.3111765113974.911.4
Nominal Pipe Size: 3/4"
4.0E-50.040.630.1150.3815851620.070.162
5.0E-50.050.790.1440.4723282370.1030.24
6.0E-50.060.950.1730.5732103270.1420.33
7.0E-50.071.110.20.6641754260.1850.43
8.0E-50.081.270.230.7653265430.240.54
9.0E-50.091.430.260.8564196550.280.66
1.0E-40.11.590.290.9577277880.340.79
1.1E-40.111.740.321.0493509530.410.95
1.2E-40.121.90.351.141084211060.481.11
1.3E-40.132.10.381.231238912630.551.26
1.4E-40.142.20.41.331436914650.641.47
1.5E-40.152.40.431.421604916360.711.64
1.6E-40.162.50.461.521826018620.811.86
1.7E-40.172.70.491.612004120440.892.0
1.8E-40.182.90.521.72246822910.992.3
1.9E-40.193.00.551.82503425531.112.6
2.0E-40.23.20.581.892694627481.192.8
3.0E-40.34.80.872.85706258192.55.8
4.0E-40.46.31.153.898274100214.310.0
5.0E-40.57.91.444.7148599151536.615.2
Nominal Pipe Size: 1"
7.0E-50.071.110.1220.412431270.0550.127
8.0E-50.081.270.140.4615881620.070.162
9.0E-50.091.430.1570.5219191960.0850.196
1.0E-40.11.590.1750.5723122360.1020.24
1.1E-40.111.740.1920.6327292780.1210.28
1.2E-40.121.90.210.6932483310.1440.33
1.3E-40.132.10.230.7437173790.1640.38
1.4E-40.142.20.240.842004280.1860.43
1.5E-40.152.40.260.8648224920.210.49
1.6E-40.162.50.280.9253425450.240.55
1.7E-40.172.70.30.9760306150.270.62
1.8E-40.182.90.311.0365786710.290.67
1.9E-40.193.00.331.0973297470.320.75
2.0E-40.23.20.351.1578958050.350.81
3.0E-40.34.80.521.721674917080.741.71
4.0E-40.46.30.72.32797128521.242.9
5.0E-40.57.90.872.94229543131.874.3
6.0E-40.69.51.053.45887560042.66.0
7.0E-40.711.11.224.08013681713.58.2
8.0E-40.812.71.44.6101058103054.510.3
9.0E-40.914.31.575.2127901130425.713.1
0.00101.015.91.755.7152264155266.715.5
0.00111.117.41.926.3184239187878.118.8
Nominal Pipe Size: 1 1/4"
1.0E-40.11.590.1240.4110371060.0460.106
1.1E-40.111.740.1370.4512261250.0540.125
1.2E-40.121.90.1490.4914241450.0630.145
1.3E-40.132.10.1620.5316301660.0720.166
1.4E-40.142.20.1740.5718431880.0810.188
1.5E-40.152.40.1870.6121162160.0940.22
1.6E-40.162.50.1990.6523462390.1040.24
1.7E-40.172.70.210.6926482700.1170.27
1.8E-40.182.90.220.7328912950.1280.3
1.9E-40.193.00.240.7832213280.1420.33
2.0E-40.23.20.250.8234733540.1530.35
3.0E-40.34.80.371.2271627300.320.73
4.0E-40.46.30.51.631196112200.531.22
5.0E-40.57.90.622.01808718440.81.85
6.0E-40.69.50.752.42517725671.112.6
7.0E-40.711.10.872.93426934941.513.5
8.0E-40.812.70.993.34321544071.914.4
9.0E-40.914.31.123.75469555772.45.6
0.00101.015.91.244.16511366402.96.6
0.00111.117.41.374.57878680343.58.0
0.00121.219.01.494.99376295614.19.6
0.00131.3211.625.3105965108054.710.8
0.00141.4221.745.7122894125325.412.5
0.00151.5241.876.1141077143866.214.4
0.00161.6251.996.5160515163687.116.4
0.00171.7272.16.9181206184788.018.5
Nominal Pipe Size: 1 1/2"
2.0E-40.23.20.1510.510621080.0470.108
3.0E-40.34.80.230.7522002240.0970.22
4.0E-40.46.30.30.9936883760.1630.38
5.0E-40.57.90.381.2454135520.240.55
6.0E-40.69.50.451.4975437690.330.77
7.0E-40.711.10.531.74992510120.441.01
8.0E-40.812.70.611.991296313220.571.32
9.0E-40.914.30.682.21584116150.71.62
0.00101.015.90.762.51955619940.862.0
0.00111.117.40.832.72281823271.012.3
0.00121.219.00.913.02715627691.22.8
0.00131.3210.983.23187032501.413.3
0.00141.4221.063.53559336291.573.6
0.00151.5241.143.74085941661.814.2
0.00161.6251.214.04648847402.14.7
0.00171.7271.294.25248153522.35.4
0.00181.8291.364.55657457692.55.8
0.00191.9301.444.76303564282.86.4
0.00202.0321.515.06984471223.17.1
0.00303.0482.37.5150864153846.715.4
Nominal Pipe Size: 2"
4.0E-40.46.30.1810.5910531070.0470.107
5.0E-40.57.90.230.7415481580.0680.158
6.0E-40.69.50.270.8921592200.0950.22
7.0E-40.711.10.321.0428442900.1260.29
8.0E-40.812.70.361.1935913660.1590.37
9.0E-40.914.30.411.3445454630.20.46
0.00101.015.90.451.4954185520.240.55
0.00111.117.40.51.6465566680.290.67
0.00121.219.00.541.7875237670.330.77
0.00131.3210.591.9388299000.390.9
0.00141.4220.632.11024010440.451.05
0.00151.5240.682.21132011540.51.16
0.00161.6250.732.41287913130.571.31
0.00171.7270.772.51453914830.641.48
0.00181.8290.822.71630016620.721.66
0.00191.9300.862.81746317810.771.78
0.00202.0320.913.01935019730.861.98
0.00303.0481.364.54179542621.854.3
0.00404.0631.815.97120772613.17.3
0.00505.0792.37.4111260113454.911.4
0.00606.0952.78.9153249156276.815.6
Nominal Pipe Size: 2 1/2"
7.0E-40.711.10.220.7412391260.0550.126
8.0E-40.812.70.260.8415651600.0690.16
9.0E-40.914.30.290.9519151950.0850.195
0.00101.015.90.321.0523652410.1050.24
0.00111.117.40.351.1627622820.1220.28
0.00121.219.00.381.2632883350.1450.34
0.00131.3210.421.3737203790.1640.38
0.00141.4220.451.4743154400.1910.44
0.00151.5240.481.5849535050.220.51
0.00161.6250.511.6854275530.240.55
0.00171.7270.551.7961276250.270.63
0.00181.8290.581.8968697000.30.7
0.00191.9300.612.076537800.340.78
0.00202.0320.642.184808650.370.87
0.00303.0480.963.21761217960.781.8
0.00404.0631.284.23000530601.333.1
0.00505.0791.65.34688347812.14.8
0.00606.0951.926.36457665852.96.6
0.00707.01112.27.48789689633.99.0
0.00808.01272.68.4114802117065.111.7
0.00909.01432.99.5138692141426.114.2
0.0110.01593.210.5171225174607.617.5
Nominal Pipe Size: 3"
0.00121.219.00.250.8211701190.0520.119
0.00131.3210.270.8913261350.0590.135
0.00141.4220.290.9615381570.0680.157
0.00151.5240.311.0317661800.0780.18
0.00161.6250.331.119371980.0860.198
0.00171.7270.361.1721872230.0970.22
0.00181.8290.381.2424522500.1080.25
0.00191.9300.41.326312680.1160.27
0.00202.0320.421.3729152970.1290.3
0.00303.0480.632.160546170.270.62
0.00404.0630.842.71031410520.461.05
0.00505.0791.053.41611616430.711.64
0.00606.0951.264.12219722630.982.3
0.00707.01111.464.83021330811.343.1
0.00808.01271.675.53946240241.744.0
0.00909.01431.886.24767448612.14.9
0.0110.01592.16.95885760022.66.0
0.01111.01742.37.67121772623.17.3
0.01212.01902.58.28475486423.78.7
0.01313.02062.78.999468101434.410.2
0.01414.02222.99.6115360117635.111.8
0.01515.02383.110.3126122128615.612.9
0.01616.02543.311.0143499146336.314.6
0.01717.02693.611.7161997165197.216.5
0.01818.02853.812.4181616185198.018.5
Nominal Pipe Size: 3 1/2"
0.00202.0320.280.9110721090.0470.109
0.00303.0480.411.3622332280.0990.23
0.00404.0630.551.8138113890.1680.39
0.00505.0790.692.357065820.250.58
0.00606.0950.832.778608010.350.8
0.00707.01110.973.21069810910.471.09
0.00808.01271.113.61397314250.621.43
0.00909.01431.244.11688117210.751.72
0.0110.01591.384.52084121250.922.1
0.01111.01741.525.02521725711.112.6
0.01212.01901.665.43001130601.333.1
0.01313.02061.85.93354434201.483.4
0.01414.02221.936.33890339671.724.0
0.01515.02382.16.84465945541.974.6
0.01616.02542.27.35081251812.25.2
0.01717.02692.37.75736258492.55.9
0.01818.02852.58.26430965582.86.6
0.01919.03012.68.67165373063.27.3
0.02203172.89.17939480963.58.1
0.03304764.113.6169704173057.517.3
Nominal Pipe Size: 4"
0.00303.0480.371.216491680.0730.168
0.00404.0630.491.6128142870.1240.29
0.00505.0790.612.042144300.1860.43
0.00606.0950.732.458055920.260.59
0.00707.01110.862.879018060.350.81
0.00808.01270.983.21031910520.461.05
0.00909.01431.13.61246712710.551.27
0.0110.01591.224.01539115690.681.57
0.01111.01741.354.41862318990.821.9
0.01212.01901.474.82216322600.982.3
0.01313.02061.595.22477225261.092.5
0.01414.02221.715.62873029301.272.9
0.01515.02381.846.03298133631.463.4
0.01616.02541.966.43752538261.663.8
0.01717.02692.16.84236243201.874.3
0.01818.02852.27.24749348432.14.8
0.01919.03012.37.65291653962.35.4
0.02203172.48.05863359792.66.0
0.03304763.712.0125328127805.512.8
Nominal Pipe Size: 5"
0.00505.0790.391.2714131440.0620.144
0.00606.0950.471.5319501990.0860.199
0.00707.01110.541.7825392590.1120.26
0.00808.01270.622.033163380.1470.34
0.00909.01430.72.341974280.1850.43
0.0110.01590.782.549465040.220.5
0.01111.01740.852.859846100.260.61
0.01212.01900.933.171227260.310.73
0.01313.02061.013.383588520.370.85
0.01414.02221.093.692329410.410.94
0.01515.02381.173.81059810810.471.08
0.01616.02541.244.11205812300.531.23
0.01717.02691.324.31361213880.61.39
0.01818.02851.44.61526115560.671.56
0.01919.03011.484.81700417340.751.74
0.02203171.555.11884019210.831.92
0.03304762.37.64027141061.784.1
0.04406343.110.26782669163.06.9
0.05507933.912.7105978108074.710.8
0.06609514.715.3152608155616.715.6
Nominal Pipe Size: 6"
0.00707.01110.381.2310531070.0470.107
0.00808.01270.431.4113151340.0580.134
0.00909.01430.481.5916651700.0740.17
0.0110.01590.541.7620552100.0910.21
0.01111.01740.591.9423742420.1050.24
0.01212.01900.642.128252880.1250.29
0.01313.02060.72.333163380.1470.34
0.01414.02220.752.538453920.170.39
0.01515.02380.812.642044290.1860.43
0.01616.02540.862.847834880.210.49
0.01717.02690.913.054005510.240.55
0.01818.02850.973.260546170.270.62
0.01919.03011.023.367456880.30.69
0.02203171.073.574747620.330.76
0.03304761.615.31597516290.711.63
0.04406342.17.02690527441.192.7
0.05507932.78.84204042871.864.3
0.06609513.210.66053761732.76.2
0.077011103.812.38239884023.68.4
0.088012684.314.1101643103654.510.4
0.099014274.815.9128642131185.713.1
0.110015855.417.6158817161957.016.2
0.1111017445.919.4192168195958.519.6
Nominal Pipe Size: 8"
0.01414.02220.451.4610411060.0460.106
0.01515.02380.481.5711951220.0530.122
0.01616.02540.511.6713591390.060.139
0.01717.02690.541.7814621490.0650.149
0.01818.02850.571.8816391670.0720.167
0.01919.03010.61.9818261860.0810.186
0.02203170.642.120232060.0890.21
0.03304760.953.143244410.1910.44
0.04406341.274.272837430.320.74
0.05507931.595.21137911600.51.16
0.06609511.916.31638616710.721.67
0.077011102.27.32106421480.932.2
0.088012682.58.42751328051.222.8
0.099014272.99.43482135511.543.6
0.110015853.210.44298843841.94.4
0.1111017443.511.55201653042.35.3
0.1212019023.812.56190363122.76.3
0.1313020614.113.67265074083.27.4
0.1414022194.514.68425785923.78.6
0.1515023784.815.79103492834.09.3
0.1616025365.116.7103577105624.610.6
0.1717026955.417.8116928119235.211.9
0.1818028535.718.8131089133675.813.4
0.1919030126.019.8146059148946.514.9
0.220031706.421161838165037.216.5
A diagram presentation of the tables above can be found in "Steel Pipe Schedule 40 - Friction loss and Velocity Diagram".
