Engineering ToolBox > Recommended Suction Flow Velocity of Viscous Fluids
Recommended suction flow velocity of viscous fluids
Avoid high velocities in the suction pipes. Higher velocities increases the pressure loss in the pipe and there may be a chance that the pump start to cavitating. As a rule of thumb the suction velocity in front of a pump should be below:
Pipe bore Viscous Liquids
inches mm m/s ft/s
1 25 0.3 1
2 50 0.33 1.1
3 75 0.36 1.2
4 100 0.4 1.3
6 150 0.43 1.4
8 200 0.45 1.5
10 250 0.5 1.7
12 300 0.5 1.7
These values depends a lot of the fluid pumped. More about viscosity and viscosities of different fluids can be read here:
