Engineering ToolBox > Discharge Regulation of Centrifugal Pumps
Adapting pump capacities to process demand
It is often necessary to adapt the pump capacity to a temporary or permanent change in the process demand.
The capacity of a centrifugal pump can be regulated either at
Capacity Regulating by Varying Speed
pump speed regulating
Speed regulating is energy efficient since the energy to the pump is reduced with the decrease of speed.
The speed of the pump can be varied with
The change in power consumption, head and volume rate can be estimated with the affinity laws.
Capacity Regulating by Constant Speed
Capacity can be regulated at constant speed by
Throttling
Throttling can be carried out by opening and closing a discharge valve.
pump regulation throttling
Throttling is energy inefficient since the energy to the pump is not reduced. Energy is wasted by increasing the dynamic loss.
Bypassing Flow
The discharge capacity can be regulated by leading a part of the discharge flow back to the suction side of the pump. Bypassing the flow is energy inefficient since the energy to the pump is not reduced.
Changing the Impeller Diameter
Reducing the impellers diameter is a permanent change and the method can be used where the change in process demand is temporary. The method may be energy efficient if the motor is changed and the energy consumption reduced.
Modifying the Impeller
The flow rate and the head can be modulated by changing the pitch of the blades. Complicated and seldom used.
Pump Regulation and Power Consumption
Power consumption of some of the regulating methods are compared in the figure below:
pump regulation power efficiency
