Engineering ToolBox > PVC and CPVC Pipes - Pressure Ratings
Maximum operating and required burst pressure of PVC - Polyvinyl Chloride - and CPVC - Chlorinated Polyvinyl Chloride - pipe fittings
Maximum operating and required minimum bursting pressure at 73oF (23oC) for PVC and CPVC piping fittings according ASTM D1785 "Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Pipe, Schedules 40, 80, and 120" can be found in the diagram and table below:
pvc pipes - bursting and operating pressure limits diagram
PVC and CPVC Pipes
Nominal Pipe Size
(inches)
Required Minimum Burst Pressure
(psi)
Maximum Operating Pressure
(psi)
Schedule 401) Schedule 802) Schedule 40 Schedule 80
1/2 1910 2720 358 509
3/4 1540 2200 289 413
1 1440 2020 270 378
1 1/4 1180 1660 221 312
1 1/2 1060 1510 198 282
2 890 1290 166 243
2 1/2 870 1360 182 255
3 840 1200 158 225
4 710 1110 133 194
5 620 1040 117 173
6 560 930 106 167
8 500 890 93 148
10 450 790 84 140
12 450 600 79 137
  1. ASTM D2466-02 "Standard Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Pipe Fittings, Schedule 40"
  2. ASTM D2466-02 "Standard Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Pipe Fittings, Schedule 80"
Note! The maximum operating pressure derates with temperature. At maximum operating temperature for PVC (140oF, 60oC) the strength is derated to approximately 20% of the strength at 73oF (23oC). For CPVC the strength is reduced to 20% of the initial strength at 200oF (93oC).
Be aware that maximum operating pressure varies with the design of the fittings. Consult the manufacturing data.
