Engineering ToolBox > Refrigerants - Properties
Physical properties of some common refrigerants can be found in the table below:
| Refrigerant No. | Name | Molecular Mass | Boiling point atmospheric pressure 14.7 psia, 1 bar abs) (oF) | Freezing Point atmospheric pressure 14.7 psia, 1 bar abs (oF) | Critical Point | ||
| Temperature (oF) | Pressure (psia) | Specific Volume (Cu.Ft./lb.) | |||||
| R-11 | Trichlorofluoromethane1) | 137.37 | 74.9 | -168 | 388 | 640 | 0.0289 |
| R-12 | Dichlorodifluoromethane2) | 120.91 | -21.8 | -252 | 234 | 597 | 0.0287 |
| R-13 | Chlorotrifluoromethane | 104.46 | -114.6 | -294 | 84 | 561 | 0.0277 |
| R-13B1 | Bromotrifluoromethane | 148.91 | -72 | -270 | 153 | 575 | 0.0215 |
| R-14 | Tetrafluoromethane (Carbon tetrafluoride) | 88.00 | -198.2 | -299 | -50 | 543 | 0.0256 |
| R-21 | Dichloro-fluoromethane | 102.92 | 48.1 | -211 | |||
| R-22 | Chlorodifluoromethane3) | 86.468 | -41.3 | -256 | 205 | 722 | 0.0305 |
| R-40 | Chloromethane (Methyl Chloride) | 50.488 | -10.7 | -144 | 290 | 969 | 0.0454 |
| R-50 | Methane | 16.044 | -259 | -296.6 | |||
| R-113 | Trichlorotrifluoroethane4) | 187.39 | 118 | -31 | 417 | 499 | 0.0278 |
| R-114 | 1,2-dichloro-1,1,2,2-tetrafluoroethane | 170.92 | 38.4 | -137 | 294 | 473 | 0.0275 |
| R-115 | Chloropentafluoroethane | 154.47 | -38.0 | -149 | 176 | 458 | 0.0261 |
| R-123 | Dichlorotrifluoroethane5) | 152.93 | 82 | -161 | 363 | 533 | |
| R-134a | Tetrafluoroethane6) | 102.03 | -15 | -142 | 214 | 590 | 0.0290 |
| R-142b | 1-chloro-1,1-difluoroethane | 100.50 | 14 | -204 | 279 | 598 | 0.0368 |
| R-152a | Difluoroethane | 66.05 | -13 | ||||
| R-160 | Ethyl Chloride | 64.515 | 12.2 | -218 | |||
| R-170 | Ethane | 30.070 | -127 | -278 | 90 | 710 | 0.0830 |
| R-290 | Propane | 44.097 | -44 | -309.8 | 206 | 617 | 0.0728 |
| RC-318 | Octafluorocyclobutane | 200.04 | 22 | -43 | 240 | 404 | 0.0258 |
| R-410A | R-32 Difluoromethane (50% weight), R-125 Pentafluoroethane (50% weight) | 72.6 | -55.4 | 162 | 690 | ||
| R-500 | Dichlorodifluoromethane/ Difluoroethane7) | 99.31 | -28 | -254 | 222 | 642 | 0.0323 |
| R-502 | Chlorodifluoromethane/ Chloropentafluoroethane | 111.63 | -50 | 180 | 591 | 0.0286 | |
| R-503 | Chlorotrifluoromethane/ Trifluoromethane | 87.50 | -128 | 67 | 607 | 0.0326 | |
| R-600 | n-Butane | 58.12 | 31.2 | -217 | 306 | 551 | 0.0702 |
| R-600a | Isobutane (2-Methyl propane) | 58.12 | 10.8 | -229 | 275 | 529 | 0.0725 |
| R-611 | Methyl formate | 60.05 | 89 | -146 | 417 | 870 | 0.0459 |
| R-702 | Hydrogen | 2.016 | -423 | -434.6 | |||
| R-704 | Helium | 4.0026 | -452 | ||||
| R-717 | Ammonia | 17.02 | -28 | -107.9 | 271 | 1657 | 0.0680 |
| R-720 | Neon | 20.179 | -410.9 | -415.6 | |||
| R-728 | Nitrogen | 28.0134 | -320.4 | -346 | |||
| R-729 | Air | 28.966 | -320 | -357.2 | |||
| R-732 | Oxygen | 31.9988 | -297.3 | -361.3 | |||
| R-740 | Argon | 39.948 | -303 | -308.5 | |||
| R-744 | Carbon Dioxide | 44.01 | -109.4 | -70 | 88 | 1070 | 0.0342 |
| R-744A | Nitrous Oxide | 44.012 | -127.3 | -131.5 | |||
| R-764 | Sulfur Dioxide | 64.06 | 14.0 | -104 | 316 | 1143 | 0.0306 |
| R-1150 | Ethylene | 28.05 | -155 | -272 | 49 | 742 | 0.0700 |
| R-1270 | Propylene | 42.08 | -54 | -301 | 197 | 670 | 0.0720 |
1) Production of R11 or CFC-11 was halted by the clean air act on January 1, 1996
2) Production of R12 or CFC-12 (Freon) was halted by the clean air act on January 1, 1996
3) R22 or HCFC-22 is a single component HCFC refrigerant with low ozone depletion potential. It has long been used in a variety of air-conditioning and refrigeration applications in a variety of markets, including appliance, construction, food processing, and supermarkets
4) Production of R113 or CFC-113 was halted by the clean air act on January 1, 1996
5) R123 or HCFC-123 is a replacement for R11 in chillers and is providing this new refrigerant to chiller manufacturers for use in new and existing chillers
6) Refrigerant R134a or HFC-134a is a commercially available hydrofluorocarbon (HFC) refrigerant for use as a long-term replacement for R-12 in new equipment and for retrofitting medium temperature CFC-12 systems
7) Production of R-500 was halted by the clean air act on January 1, 1996.
Typical low, medium and high pressure refrigerants are listed in the table below:
| Refrigerants | ||
| Low Pressure | R11 | Trichlorofluoromethane |
| R13 | Chlorotrifluoromethane | |
| R113 | Trichlorotrifluoroethane | |
| R123 | Dichlorotrifluoroethane | |
| Medium Pressure | R114 | 1,2-dichloro-1,1,2,2-tetrafluoroethane |
| High Pressure | R12 | Dichlorodifluoromethane |
| R22 | Chlorodifluoromethane | |
| R134a | Tetrafluoroethane | |
| R410A | Difluoromethane/Pentafluoroethane | |
| R500 | Dichlorodifluoromethane/ Difluoroethane | |
| R502 | Chlorodifluoromethane/ Chloropentafluoroethane | |
Refrigerants can be classified as CFS's - ChloroFluoroCarbons refrigerants, HCFC's - HydroChloroFluorCarbons refrigerants, HFC's - HydroFluorCarbons refrigerants and HC - HydroCarbon refrigerants.
| Refrigerants | ||
| CFS ChloroFluoroCarbons | R11 | Trichlorofluoromethane |
| R12 | Dichlorodifluoromethane | |
| R114 | 1,2-dichloro-1,1,2,2-tetrafluoroethane | |
| R503 | Chlorotrifluoromethane/ Trifluoromethane | |
| HCFC HydroChloroFluorCarbons | R22 | Chlorodifluoromethane |
| R124 | Chlorotetrafluoroethane | |
| R401a | R22(53%)/R152a(13%)/R124(34%) | |
| R401b | R22(61%)/R152a(11%)/R124(28%) | |
| R402a | R22(38%)/R125(60%)/R290(2%) | |
| R403b | R22(56%)/R218(39%)/R290(5%) | |
| R406a | R22(55%)/R600a(4%)/R142b(41%) | |
| R408a | R125(7%)/R143a(46%)/R22(47%) | |
| R409a | R22(60%)/R124(25%)/R142b(15%) | |
| HFC HydroFluorCarbons | R23 | Trifluoromethane |
| R404a | R125(44%)/R143a(52%)/R134a(4%) | |
| R407a | R32(20%)/R125(40%)/R134a(40%) | |
| R410a | R32(50%)/R125(50%) | |
| R416a | R134a(59%)/R124(39.5%)/R600(1.5%) | |
| R507 | R125(50%)/R143a(50%) | |
| R508a | R23(39%)/R116(61%) | |
| HC HydroCarbons | R600 | butane |
| R600a | iso-butane | |
