Engineering ToolBox > Refrigerants
Common refrigerants - methane series, ethane series, propane series, cyclic organic compounds, zeotropic blends, azeotropic blends and organic compounds
Methane Series
Ethane Series
Propane Series
Cyclic Organic Compounds
Zeotropic Blends
The properties of zeotropic blends are somewhat different than traditional refrigerants. Zeotropic blends shift in composition during the boiling or condensing process. As the blend changes phase, more of one component will transfer to the other phase faster than the rest.
Note! % by mass
The changing composition of the liquid - fractionation - causes the boiling point temperature of the refrigerant to shift as well. The overall shift of temperature from one side of the heat exchanger to the other is called the temperature glide.
Azeotropic Blends
Azeotropic blends behaves as a single component refrigerants even though they are blends. Single component refrigerants and azeotropic blends have boiling (bubble) points and condensation (dew) points equal to each other - simply called boiling point.
Note! % by mass
Miscellaneous Organic Compounds
Hydrocarbons
Oxygen Compounds
Sulfur Compounds
Nitrogen Compounds
Unsaturated Organic Compounds
