Engineering ToolBox > Resistivity, Conductivity and Temperature Coefficients for some Common Materials
The factor in the resistance which takes into account the nature of the material is the resistivity.
| Material | Resistivity Coefficient 2) - ρ - (ohm m) | Temperature Coefficient 2) per degree C | Conductivity - σ - (1 /Ωm) |
| Aluminum | 2.65 x 10-8 | 3.8 x 10-3 | 3.77 x 107 |
| Antimony | 41.8 x 10-8 | ||
| Beryllium | 4.0 x 10-8 | ||
| Bismuth | 115 x 10-8 | ||
| Cadmium | 7.4 x 10-8 | ||
| Carbon (graphite)1) | 3 - 60 x 10-5 | -4.8 x 10-3 | |
| Chromel (alloy of chromium and aluminum) | 0.58 x 10-3 | ||
| Chromium | 13 x 10-8 | ||
| Cobalt | 9 x 10-8 | ||
| Constantan | 49 x 10-8 | 0 | 0.20 x 107 |
| Copper | 1.724 x 10-8 | 4.29 x 10-3 | 5.95 x 107 |
| Eureka | 0.1 x 10-3 | ||
| Iron | 9.71 x 10-8 | 6.41 x 10-3 | 1.03 x 107 |
| Germanium1) | 1 - 500 x 10-3 | -50 x 10-3 | |
| Glass | 1 - 10000 x 109 | ||
| Gold | 2.24 x 10-8 | ||
| Iridium | 5.3 x 10-8 | ||
| Iron | 9.7 x 10-8 | ||
| Lead | 20.6 x 10-8 | 0.45 x 107 | |
| Magnesium | 4.45 x 10-8 | ||
| Manganese | 185 x 10-8 | ||
| Mercury | 98.4 x 10-8 | 8.9 x 10-3 | 0.10 x 107 |
| Molybdenum | 5.2 x 10-8 | ||
| Nickel | 6.85 x 10-8 | 6.41 x 10-3 | |
| Nichrome (alloy of nickel and chromium) | 0.40 x 10-3 | ||
| Niobium (Columbium) | 13 x 10-8 | ||
| Osmium | 9 x 10-8 | ||
| Platinum | 10.5 x 10-8 | 3.93 x 10-3 | 0.943 x 107 |
| Plutonium | 141.4 x 10-8 | ||
| Potassium | 7.01 x 10-8 | ||
| Quartz (fused) | 7.5 x 1017 | ||
| Rhodium | 4.6 x 10-8 | ||
| Rubber - hard | 1 - 100 x 1013 | ||
| Selenium | 12.0 x 10-8 | ||
| Silicon1) | 0.1-60 | -70 x 10-3 | |
| Silver | 1.59 x 10-8 | 6.1 x 10-3 | 6.29 x 107 |
| Sodium | 4.2 x 10-8 | ||
| Tantalum | 12.4 x 10-8 | ||
| Thorium | 18 x 10-8 | ||
| Tin | 11.0 x 10-8 | ||
| Titanium | 43 x 10-8 | ||
| Tungsten | 5.65 x 10-8 | 4.5 x 10-3 | 1.79 x 107 |
| Uranium | 30 x 10-8 | ||
| Vanadium | 25 x 10-8 | ||
| Zinc | 5.92 x 10-8 |
1) The resistivity depends strongly on the presence of impurities in the material
2) Resistivity and Temperature Coefficients at 20oC reference
The electrical resistance of a wire is greater for a longer wire and less for a wire of larger cross sectional area. The resistance depend on the material of which it is made and can be expressed as:
R = ρ L / A (1)
R = resistance (ohm)
ρ = resitivity coefficient (ohm m)
L = length of wire (m)
A = cross sectional area of wire (m2)
The factor in the resistance which takes into account the nature of the material is the resistivity. Since it is temperature dependent, it can be used to calculate the resistance of a wire of given geometry at different temperatures.
The inverse of resistivity is called conductivity and can be expressed as:
σ = 1 / ρ (2)
σ = conductivity (1 / Ω m)
The electrical resistance of a circuit component or device is defined as the ratio of the voltage applied to the electric current which flows through it:
R = V / I (3)
V = voltage (V)
I = current (A)
If the resistance is constant over a considerable range of voltage, then Ohm's law,
I = V / R (4)
can be used to predict the behavior of the material.
The electrical resistance increases with temperature. An intuitive approach to temperature dependence leads one to expect a fractional change in resistance which is proportional to the temperature change:
dR / Rs = α dT (5)
dR = change in resistance (ohm)
Rs = standard resistance according reference tables (ohm)
α = temperature coefficient of resistance
dT = change in temperature (K)
