Engineering ToolBox > Room Sensible Heat Factor - RSHF
The Room Sensible Heat Factor - RSHF - is defined as the sensible heat load in the room divided by the total heat load in room
The Room Sensible Heat Factor - RSHF - express the ratio between the sensible heat load and the total heat load in the room. It can be expressed as:
RSHF = Qsr / Qtr (1)
RSHF = room sensible heat factor
Qsr = sensible heat load in the room (kW, Btu/hr)
Qtr = total heat load in the room (kW, Btu/hr)
(1) can be modified to:
RSHF = cp (tr - ti) / (hr - hi) (2)
cp = specific heat capacity of air (kJ/kg.oC)
tr = room temperature (oC)
ti = inlet temperature (oC)
hr = room enthalpy (kJ/kg)
hi = inlet enthalpy (kJ/kg)
Example - Room Sensible Heat Factor - RSHF
The sensible heat generation in a room is 4 kW. The latent heat generation is 1.4 kW.
The Room Sensible Heat Factor can be calculated as:
RSHF = 4 kW / (4 kW + 1.4 kW)
= 0.75
