Engineering ToolBox > SAE Valve Standards
The Society of Automotive Engineers, SAE, valves standards:
| Standard Code | Standard Name |
| SAE ARP 490E | Electro hydraulic servo valves |
| SAE AS 707B | Thermal sensitive inflation pressure release devices for tubeless aircraft wheels |
| SAE ARP 745 | General components specification for explosive actuated valves one cycle |
| SAE AS 1607A | Valve starter control, pneumatic aircraft engine general specification for replaced ASE ARP 1607 |
| SAE ARP 1616A | Self-sealing breakaway valves for crash-resistant aircraft fuel and oil systems -- replace AIR 1616 |
| SAE AIR 4782 | Hydrant valve and coupler historical background |
| SAE J 747 | Control valve test procedure standard May 1990 |
| SAE J 748 | Hydraulic directional control valves 3000psi Maximum, recommended practice Dct.1957 |
| SAE J 1117 | Method of measuring and reporting the pressure differential flow characteristics of hydraulic fluid power valve, recommended practice June 1975 |
| SAE J 1118 | Hydraulic valves for motor vehicle brake systems test procedure, recommended practice Jun. 1978 |
| SAE J 1235 | Measuring and reporting the internal leakage of a hydraulic fluid power valve, Recommended practice June, 1978 |
| SAE J 1409 | Air Brake Valves Test Procedure, Recommended Practice March 1983 R(1988) |
| SAE J 1875 | Materials for Plastic Check Valves for Vacuum Booster systems, standard June 1993 |
