Engineering ToolBox > Heat Storage Materials
Physical properties of sensible heat storage materials
Thermal energy can be stored in a material as sensible heat by raising its temperature.
The heat storage can be calculated as
q = V ρ cp dt
    = m cp dt (1)
q = sensible heat stored in the material (J)
V = volume of substance (m3)
ρ = density of substance (kg/m3)
m = mass of substance (kg)
cp = specific heat capacity of the substance (J/kg oC)
dt = temperature change (oC)
Material Temperature Range
(oC)
Density
ρ -
(kg/m3)
Specific Heat
- cp -
(J/kgoC)
Energy Density
(kJ/m3 oC)
Aluminum max. 660 (melting point) 2700 920 2484
Cast Iron max. 1150 (melting point) 7200 540 3889
Fireclay   2100 - 2600 1000 2100 - 2600
50% Ethylene Glycol - 50% Water 0 - 100 1075 3480 3741
Dowtherm  A 12 - 260 867 2200 1907
Draw salt - 50% NaNO3 - 50% KNO3) (by weight) 220 - 540 1733 1550 2686
Granite   2400 790 1896
Liquid Sodium 100 - 760 750 1260 945
Molten Salt - 50% KNO3 - 40% NaNO2 - 7% NaNO3 (by weight) 142 - 540 1680 1560 2620
Taconite   3200 800 2560
Therminol 66 -9 - 343 750 2100 1575
Water 0 - 100 1000 4190 4190
Example - Heat stored in Granite
Heat stored in 2 m3 granite heated from 20oC to 40oC can be calculated as
q = 2 (m3) 2400 (kg/m3) 790 (J/kgoC) (40 - 20 )(oC)
    = 75840 kJ = 21 kWh
