Engineering ToolBox > Slurry Density
Calculate slurry density
Slurry is a mixture of solids and liquid. The density of a slurry can be calculated as
ρm = 100 / (cw / ρs  + (100 - cw) / ρl) (1)
ρm = density of slurry (lb/ft3, kg/m3)
c= concentration of solids by weight in the slurry (%)
ρs =  density of the solids (lb/ft3, kg/m3)
ρl =  density of liquid without solids (lb/ft3, kg/m3)
The slurry concentration by weight can be measured by evaporating a known weight of slurry and measuring the weight of dried solids.
Example - Calculating Slurry Density
The density of a slurry where
 ρm = 100 / (30 / 2500  + (100 - 30) / 1000)
    = 1220 kg/m3
Slurry Density Calculator
The density of a slurry can be calculated with the calculator below.
solids concentration - (%)
density solid - (kg/m3, lb/ft3)
density liquid - (kg/m3, lb/ft3)
