Engineering ToolBox > Snow Melting Systems
Sizing water antifreeze snow melting systems
A typical snow melting system should have a heating capacity of at least 100 Btu per hour per square feet (320 W/m2). This would melt up to 1.5 inch/hour (4 cm/h) snowfalls.
snow melting system
Solutions of 50% water and 50% antifreeze are common, but the solution used should always be adapted to local temperature and system conditions. Note that metal pipes, like copper, will break if the solution inside the tubes freezes. Plastic pipes may in general freeze without breaking.
Coils in Concrete Layers
Coils in Blacktop or Asphalt Layers
