Engineering ToolBox > Gases - Specific Gravities
The specific gravity of some common gases can be found in the table below:
| Gas | Specific Gravity1) - SG - |
| Acetylene (ethyne) - C2H2 | 0.90 |
| Air1) | 1.000 |
| Ammonia - NH3 | 0.59 |
| Argon - Ar | 1.38 |
| Arsine | 2.69 |
| Benzene - C6H6 | 2.6961 |
| Blast Furnace gas | 1.02 |
| Butadiene - C4H6 | 1.87 |
| Butane - C4H10 | 2.0061 |
| 1-Butene (Butylene)- C4H8 | 1.94 |
| Isobutene - C4H8 | 1.94 |
| Carbon dioxide - CO2 | 1.5189 |
| Carbon monoxide - CO | 0.9667 |
| Carbureted Water Gas | 0.63 |
| Chlorine - Cl2 | 2.486 |
| Coke Oven Gas | 0.44 |
| Cyclobutane | 1.938 |
| Cyclopentane | 2.422 |
| Cyclopropane | 1.451 |
| Decane | 4.915 |
| Deutrium - D2 | 0.070 |
| Digestive Gas (Sewage or Biogas) | 0.8 |
| Ethane - C2H6 | 1.0378 |
| Ethyl Chloride - C2H5Cl | 2.23 |
| Ethylene (Ethene) - C2H4 | 0.9683 |
| Fluorine | 1.31 |
| Helium - He | 0.138 |
| Heptanes | 3.459 |
| Hexane | 2.973 |
| Hydrogen | 0.0696 |
| Hydrogen chloride - HCl | 1.268 |
| Hydrogen sulfide - H2S | 1.1763 |
| Isobutane | 2.01 |
| Isopentane | 2.48 |
| Krypton | 2.89 |
| Methane - CH4 | 0.5537 |
| Methyl Chloride | 1.74 |
| Natural Gas (typical) | 0.60 - 0.70 |
| Neon | 0.697 |
| Nitric oxide - NO | 1.037 |
| Nitrogen - N2 (pure) | 0.9669 |
| Nitrogen - N2 (atmospheric) | 0.9723 |
| Nitrous oxide - N2O | 1.530 |
| Nonane | 4.428 |
| Octane | 3.944 |
| Oxygen - O2 | 1.1044 |
| Ozone | 1.660 |
| Pentane | 2.487 |
| Phosgene | 1.39 |
| Propane - C3H8 | 1.5219 |
| Propene (Propylene) - C3H6 | 1.4523 |
| Sasol | 0.42 |
| Silane | 1.11 |
| Sulfur Dioxide - SO2 | 2.264 |
| Toluene-Methylbenzene | 3.1082 |
| Water Gas (bituminous) | 0.71 |
| Water Vapor | 0.6218 |
| Xenon | 4.53 |
1) NTP - Normal Temperature and Pressure - is defined as air at 20oC (293.15 K, 68oF) and 1 atm ( 101.325 kN/m2, 101.325 kPa, 14.7 psia, 0 psig, 30 in Hg, 760 torr)
Since specific gravity is the ratio between the density (mass per unit volume) of the actual gas and the density of air, specific gravity has no dimension.
