Engineering ToolBox > Ratio of Specific Heat
The heat capacity of a gas in a constant pressure process - to the heat capacity of a gas in a constant volume process
Internal Energy
For an ideal gas the internal energy - u - is a function of temperature and the change in internal energy can be expressed as
du = cv dT (1)
du = change in internal energy
cv = specific heat capacity for the gas in a constant volume process
dT = change in temperature
cv varies with temperature, but within a moderate temperature change the heat capacity - cv - can be regarded as constant.
Enthalpy
For an ideal gas the enthalpy - h - is function of temperature and the change in enthalpy can be expressed as
dh = cp dT (2)
dh = change in enthalpy
cp= specific heat capacity for the gas in a constant pressure process
cp can within a moderate temperature change be regarded as constant.
The enthalpy in a fluid is defined as:
h = u + p / ρ (3)
h = enthalpy
u = internal energy
p = absolute pressure
ρ = density
Combining (3) and the Ideal Gas Law gives:
h = u + R T (4)
R = the individual gas constant
The change in enthalpy can be expressed by differentiating (4):
dh = du + R dT (5)
Dividing (5) with dT gives:
(dh / dT) - (du / dT) = R (6)
Modifying (6) with (1) and (2):
cp - cv = R (7)
The difference cp - cv is constant for an ideal gas.
The Ratio of Specific Heats
The Ratio of Specific Heats can be expressed as:
k = cp / cv (8)
k = the ratio of specific heats
Ratio of Specific Heats for some common gases:
Gas Ratio of Specific Heats
Carbon Dioxide 1.3
Helium 1.66
Hydrogen 1.41
Methane or Natural Gas 1.31
Nitrogen 1.4
Oxygen 1.4
Standard Air 1.4
Since the ratio is dimensionless the value is the same in the SI and the imperial system of units.
