Engineering ToolBox > Speed of Sound Calculator
An online Speed of Sound calculator for air
Velocity of sound in air (or in other gases) can be expressed as
c = (k p / ρ)1/2
    = (k R T)1/2 (1)
c = sound velocity (m/s, ft/s)
k = ratio of specific heats (adiabatic index, isentropic expansion factor)
p = pressure (Pa, psi)
R = 287.053072 (J/kg K)  =  1,716 (ft lb/slug oR) = gas constant specific for air
T = absolute temperature (K, R)
The calculators below can be used to estimate velocity of sound in air at temperatures close to 273.15 K (0oC, 32oF).
Sound Velocity - SI Units
k - ratio of specific heats
R - gas constant (J/kg K)
T - absolute temperature (K)
Sound Velocity - Imperial Units
R - gas constant (ft lb/slug oR)
T - absolute temperature (R)
